kunkernator
So, i recently came across a 60 gallon air tank. it is in 100% perfect condition, manufactured in 2009. The cylinder was just bad.
This is what I am planning on doing to it, but I want the internet's assistance on how safe it is. I currently have a 30 gallon compressor which shuts off at 150psi. I want to plumb this new 60 gallon tank in tandem to the 30 gallon compressor; so that the 30 gallon pump pressurises both tanks. I have no concern with the pump/motor because they are both rated at 100% duty cycle. My concern is with this new tank. The stock shutoff for this 60 gallon tank is at 125psi, the pressure relief valve is set for 150psi, and the tank is rated for MAWP (maximum allowable working pressure) at 150psi. Would it be alright to pressurise the tank to 150psi? From what I understand, it would be ok, given the working pressure maximum rating is 150psi. I would replace the pressure relief valve with one that is rated at 160psi.
So, to the point; is it safe to operate a MAWP@150psi tank at 150psi consistently? I say yes, what do you say?
EDIT: I might add that the MAWP is rated 150psi@400 degrees F......
said it took out the garage door. Every time the talk of pressurized tanks comes up, he reminds us of his adventure.
