I have a new to me Craftsman oiless unit - Model #919.165570
It has a drain that looks like this:
When the tank moves you can hear the liquid inside so tried draining it, Nothing. So next I took out the drain plug and again Nothing came out. Next I put the drain plug back in and turn it on to fill the tank and then took out the drain plug expecting it to shoot like a rocket. Nothing....at 100 PSI only a few dribbles. So I guess this means it full of sludge somehow since it's oiless. Next, with the drain plug removed I stick a screwdriver in the hole expecting **** to start shooting out (it's still got 100 psi) and nothing...I can feel some resistance inside the drain hole. Does the pipe plug that the drain valve screws into have a screen over the hole?
I tried to remove the pipe plug like in the pic above to see but I only had a crescent wrench with me and the plug wouldn't budge. I'm thinking of either replacing the plug or drilling it out, chasing it with a tap and installing a new ball valve drain.
Any thoughts/insights are appreciated.
