Nez02
I would like to add a toggle switch so I can turn my compressor on an off at the compressor. I have searched the forums and would like to add a toggle switch to the side of the magnetic starter box breaking the pressure switch. What toggle switch are you using for this application and should it be rated for 240v?
How exactly are you wiring this switch?
My compressor is a Champion two stage, 3hp motor at 240v, with a Furnas magnetic starter. Amp draw is 16.6 per the motor tag. R15 pump with a head unloader.
