catch2otwo
I recently had to replace my pressure switch on my compressor. It has an unloader valve. The original setup had a black tube that ran from the tank to the bottom of the switch. 1/4 plastic tubing. I replaced the tubing with some other "plastic" tubing that I had laying around at work. Apparently where the tubing gets attached to the tank is right where the air is being fed into the tank so there was a bit of heat. Tubing popped. What is the correct type of tubing I should buy for this application? I amazoned and googled, but i don't even know what kind of heat range I need to be looking for.
