Bought an ingersoll rand t30 (2475 pump) and put a new Leeson 7.5hp single phase motor on it. Also had to put a new check valve in it because guts of the original check valve were gone...not sure where they went (bottom of the tank, maybe?). Motor and pump sound good but the vibration definately seems abnormal. The motor looks like it's bouncing up and down. The pump and tank look steady but anything not bolted down is vibrating. All the motor and pump bolts are tight. The belt tension is good. I also checked all the tank and motor welds and all appear good.
Any ideas? Can the pulleys get out of balance? Bad motor?
