Mustang67ford
- Joined
- Apr 8, 2012
- Messages
- 87
I have a tall upright CH air compressor; 120psi is the shutoff I believe. I go the unit used from a friend several years ago and it set in storage for a few years. When I installed it, I put a shut-off valve on the bottom with a clear flex hose to drain the water every so often. When I first tried to drain it, I would open the valve a a little water would trickle out but never any air. Not knowing the inner workings of the tank, I thought maybe there was a one-way baffel or someting that would only allow the water out. So, every so often, I would get a penut butter jar to drain the water out.
Well, today The "baffel" I thought was terer went. There must have been something blocking or rust packed in the bottom of the tank because I am there with the little penut butter jar and all the sudden I was hit with a 120PSI water jet. As soon as the water hit, I lost control of the flex hose and it sprayed my walls like an out of control fire hose. I finally go the valve off and surveyed the dameage; rust covered water everywhere. I got a bucket and ended up getting another almost 2 buckets out of the tank before just air came out.
Warning to all, if you drain your tank and no air comes out.... be prepared.
