ricpad
I have a 7.5hp air compressor w/ a magnetic starter. The compressor won't turn off and constantly runs to the point which the safety valve releases at 200psi. At first I thought it was the pressure switch but even when there is no power to the pressure switch it still runs. So correct me if I'm wrong but when there is power to the pressure switch and the pressure is below the set PSI the contacts in the switch connect and send power to the magnetic starter coil (contactor?). The coil then closes the contacts to form a bridge between the 240V input power on one side to the output of power to the starter motor. If ther is no power to the pressure switch would that mean the coil is bad and is constant connection with the power in side to the power out side? When I checked with the power off and a continuity tester both ends of the coil were in continuity. Shouldn't there be no continuity if the coil is not activated by the pressure switch? Any ideas on what can be causing this situation?
Thanks
Thanks
