Hey, guys, I have an older Craftsman 25 gal compressor in great shape that runs great. I got it out this morning to pump up some tires because the weather turned sharply cooler. I did the pickup first then started on a crossover ute; on the 4th tire I ran out of air, so I re-started the compressor. It built up pressure normally. I cut it off since I didn't need the whole 125 psi but still no air. I looked at the gauge on the water separator and it had pressure. Pushed the water release button under the bowl and compressed air blew out. I had two hoses put together so I took them apart - no air. So air is on the tank gauge and on the separator gauge but not making it to the hose.
I decided the separator is bad so tomorrow I'm going to take it off and run the hose straight. I don't guess I need the separator since I mainly use the thing for pumping up tires and maybe the impact wrench once in awhile. It didn't have one when I got the compressor from my FIL's garage so I re-plumbed it and installed one. But I wouldn't mind having it on there if there's any way to fix it. It has a variable pressure control on the separator so you can control the pressure for certain applications. I tried fiddling with that but still couldn't get air past the separator.
Has anybody run into something like this before?
