Air Compressors in tandem single inlet.
wasit
I have a CNC plasma cutter that requires 105 to 125 psi air pressure to operate correctly. When I first installed it, I jacked the psi on my main air compressor up to 125 psi. This was too much for the rest of the shop as it had always been 80 to 115 psi range.
I have a refrigerated moisture removal unit after the main compressor.
I had installed a secondary air compressor close to the plasma cutter so I could use the existing dried air to feed the plasma. In order to get it to run, because the supplied shop air was too much pressure and the pump just stalled when trying to start, I installed a Asco valve to start and stop flow, a regulator to cut the pressure feeding a/c #2 down to 30 psi (normal air pressure is 29.9 or there about). These two items were before the 2nd a/c. There are 3 one way flow control valves in there too.
The issue I am having now is that my regulation system is choking the flow, just wondering if someone else had an issue like this and what was their solution?
u3b3rg33k
are you saying you have air compressors in series? or something else?
I have upgraded to better regulators for some machines, Wilkerson B18 series solved a bunch of issues for me.
MacMcMacmac
canada
They are in series. The second unit uses pre-compressed dried air into the inlet. It's acting as a booster compressor. I think it would have been a lot easier to keep the main compressor at 125 and regulate the pressure to the rest of the shop.
I think you have confused 29" Hg absolute (1 atmosphere @ sea level) with 30psig at the inlet of your second compressor.
Sumboodie
AK
Why are the compressors set so low?
Most shop air is 150-175psi and regulated down near the point of use.
I feed my plasma cutter 150psi. Regulator on it set to ~90
whateg01
doo dah, kansas, usa
Most? My compressor shut off is 135 and it's regulated down to about 100. Not everybody runs a 175 psig compressor
