I'm looking for an air compressor for home projects that's relatively quiet and is powerful enough to run some air tools such as impact wrench and cutting tool. No current plans for sand blasting or painting so far, but some friends said to buy a level higher than what I need now so opportunities are open.
For more quiet models, I'm looking for a cast iron, oil lubricated, belt driven system. That hopefully helps with reliability, too.
I'm currently trying to decide between 'portable' model with 20 or 30 gallon tank and a stationary model with a 60 gallon tank. Portable models provide around 5 CFM, stationary models provide more like 10 CFM. The stationary models cost around 20% more for twice the CFM output, so I'm leaning toward those. What would you do here?
Here are some models I'm considering:
Home Depot Husky (Campbell Hausfield) VT6314
- 60gal 135psi vertical stationary 254 lb 220V
- 11.5 / 10.2 cfm
• cast iron, oil lubricated, 1070 RPM
- 2 yr warranty, $438 (use 10% coupon: $394)
Puma Model# PK6060V
- 60 gal 150psi vertical stationary 305 lbs 220V 15amp
- 12.0 / 13.5
- 1/2" air outlet, oil sight gauge
- Oil-lubricated, belt-driven, single stage, cast iron, 2-cylinder, 50% duty cycle
- Rebuildable pump rod inserts and replaceable valves for extra-long pump life
- 1 yr warranty, $489
Puma Model# PK5020VP (same as Ingersoll Rand Garage Mate unit)
- 20gal 150psi vertical portable 110V/220V 15/7.5 Amp dual voltage
- 5.5 / 7.1 cfm
- Oil-lubricated, belt-driven, single stage, cast iron, 2-cylinder rebuildable pump
- Built-in regulator controls air pressure to air tools
- 1/4" air outlet, oil sight gauge and easy-start valve
- 1 yr warranty, $399
Home Depot Husky (Campbell Hausfield) VT6315
- 30gal 135psi vertical portable 178lb 120V (dual voltage?)
- 5.5 / 6.5 cfm
- cast iron, oil lubricated, twin cylinder pump (1070rpm?)
- 2 yr warranty, $399 (use 10% coupon: $360)
- 11.5 / 10.2 cfm
Puma Model# PK6060V
- 12.0 / 13.5
- 5.5 / 7.1 cfm
- 5.5 / 6.5 cfm
