Howdy, hopefully I'm in the right place.
So I noticed my AC stopped pushing cold air and went out to investigate. Its an older Miller condenser outside the house and I had never poked around it before. With power to the unit and the thermostat set to "Cool" I could hear the audible click of the relay but neither the fan nor the compressor would run. Removing the panel it was obvious the starter capacitor had taken a dump, and probably had been dying for a while, two of the wires had visible burn damage from touching the capacitor housing.
My buddy brought me a new capacitor and we got it installed. Pushed the test button on the relay and everything came on, set the thermostat to cool and it ran cool... for a while. I went out to investigate and noticed the same sound from the relay, it clicked at a constant interval which I assumed was in response to the thermostat. With the thermostat off there is no click. With power to the unit I can push the relay test button and the compressor and fan both come on. I also replaced the damaged wires.
The relay was pretty cruddy looking as well though it showed no visible damage but seemed to be sticking in its position. My buddy had a new relay in his truck so we replaced that as well. Now there is a new relay, new capacitor, and all the visibly damaged wires are replaced.
Same symptoms though. With power to the unit I can push the test button, everything comes on, fan and compressor. With the thermostat set to cool I hear the audible click in the relay, but nothing comes on.
My HVAC buddy is out of town for the weekend, and I'm a machinist
Any ideas guys?
Any ideas guys?
Probably just a time delay board. Doesn't look like a Heat Pump/defrost board.
