air for blasting: filter first or regulator first?
metalmagpie
Seattle
I have a Kelco blasting cabinet which I've been putting back into working order. It works well now until the compressor air warms up, then the water creates problems. I have a nice matched set of filter and regulator (separate, discrete units). I will mount them piped together closely but the question is should it be filter then regulator or regulator or filter or doesn't matter?
metalmagpie
Jswain
Calgary, AB
Filter then regulator, to keep the crud out of the regulator. Both plumbed in as far away from the compressor as possible.
Busted Knucles
bradpac
Central TX
Filter, then regulator. I had a pair actually mounted to my blaster, sometimes dial down the pressure for more delicate stuff.
pancho400cid
Austin, TX
NO! NO! NO!
It's filter THEN regulator, to keep the crud out of the regulator. Both plumbed in as far away from the compressor as possible.
Justind97
Ottawa, Canada
Man, you guys are REALLY trying to confuse the guy!
It's filter then regulator, to keep the crud out of the regulator. Both plumbed in as far away from the compressor as possible.
laser3kw
northen IL
Huh? must be a regional thing
I always heard it's filter THEN regulator, to keep the crud out of the regulator. Both plumbed in as far away from the compressor as possible.
But it might be different iin other parts of the country :beer::lol_hitti
