Air hammer question
mopar4u
Just bought a used snap on 3050 air hammer as i hear its a beast. What is the difference between the 3050, 3050A and 3050B?
I have a large suspension project coming up, i live in the rust belt. What bit do you use to tackle rusted nuts and not destroy the nut and bolt?
bcradio
New Mexico
I typically won't use an air hammer on rusty fasteners except maybe as an absolute last resort.
drewvdw
Central Illinois
Nuts and bolts are cheap, especially compared to all the cussing that happens when you try to save something that should be replaced anyways...
RECox286
South Joisey (yeah, that is part of the USA)
If you are really determined to unfasten rusted fasteners
with the intent of reuse try a 50/50 mixture of acetone and
any ATF (which has a load of detergent already onboard).
Soaking will eventually work, and heat is the other alternative.
I have also tried using the rat-ta-tat method (pneumatic rivit
gun) with a blunt chisle tool. It does work, however I ruined
more fasteners than I was able to save. Persistance seems to
be the buzz word. I have no idea what the differences might
be other than mods (like on aircarft) for the different air hammer
designations.
Uncle Bob
They do make "nut splitters" for air hammers, but I have not used them.
Simply rattling the top of the bolt head with a flat air tool for a few seconds sometimes helps after penetrating oil. After that, "flame wrench". (Oil. Flame. What could go wrong ? :dunno:)
If you are removing a non-pressed FWD front bearing (typically held by 3 bolts), after penetrating oil, and the bolts are removed, use a blunt tool in the air hammer on the edge of the bearing and try to get the bearing to turn in the knuckle.
For items like tie rod ends or ball joints, as Eric the Car Guy says "Hit what it goes through !". Not with the air hammer. Use a 2-4 lb ball peen. Usuall a half dozen good wacks and it will fall out.
Murphy4570
West Deptford NJ
Rusty bolts you want to use the blue wrench, not an air hammer. Use twist sockets if the bolt heads are rotted down. Worst case weld a nut to what's left.
mopar4u
Good info, thought I've seen posts where guys use air hammer on rusty nuts, maybe they meant that they split or peel them off.
What about my other question? What is the difference between the 3050, 3050A and 3050B?
mopar4u
I assumed revisions, I got the 3050 (no A or B) and just wondering if I'm missing out on anything the A and B have besides the quick change.
stikman56
The 3050 doesn't have the rubber grip that the A and B does. I've never figured out what makes the A or B, they look the same.
Skin
Boston
the A didn't originally include the quick change chuck, it was added in later and the B made it official.
mopar4u
Rubber grip and quick change, pfffff, i can live without them. Im only a diy'r, not a full time mechanic so those little comforts missing wont bother me. As long as this hammer hits as hard as everyone swears by ill be happy.
jerseykat1
Central New Jersey
the best way to save a fastener is with heat. heat it til its cherry red then unbolt it. Thats only if you can get to it with a torch without setting anything else on fire or melting bushings.
If torch is not an option soak it in PB blaster for a 30 hour or so.
Air hammer? i prefer the IR 118max over the SO air hammers. It hits HARD and is easy to control. That's what i use. However the SO air hammers are pretty good too.
