From under the black protective cover.Where is it leaking from?
Probably a bad crimp.From under the black protective cover.
I've also got the Red Goodyear hoses for years now and no problems!
Well that is terribly useful.The flexizilla is **** to keep clean too. The silicone or whatever that green stuff is ***** in oil, grease, etc.
I bought a hose, 100fter about 15 years ago and still going great.
It's a clearish blue, was $$. Firget the brand, but it's an awesome hose.
Agreed, no idea why people rave about them.Well that is terribly useful.
That one has a crimped ferrule.I believe that flexilla hose has a reusable hose end, so perhaps it did not get assembled properly. Just pull the black cover away and see what it is.
I keep a rag near each hose reel. I wrap the rag around the hose and hold it while the flexilla hose slips thru my hand as I guide the hose on to the reel as it recoils. Keeps the hose clean.The flexizilla is **** to keep clean too. The silicone or whatever that green stuff is ***** in oil, grease, etc.
Yeah, but oil soaks in and it doesn't clean anywhere near that easy.I keep a rag near each hose reel. I wrap the rag around the hose and hold it while the flexilla hose slips thru my hand as I guide the hose on to the reel as it recoils. Keeps the hose clean.
What kind of crimps did you use there? Have a link?
I have a couple of hf hose reels. The red hoses that come on them were ok until I had a job that took a few days and I left the hose out in the summer sun. Almost overnight they were cracked and faded. Less than a week later one of them burst in an area that had cracked. I cut off the bad section and put a new end on it but I took it off the reel and it's just a spare hose in case I need more distance.I've got the HF Cheapzilla hose on my reels. It's been leak free for at least 6 years of daily use. It does look kinda grotty. But looks never made something work better.
Probably Coil hose Pneumatics FlexeelI, I have it on 3 of my reels.The flexizilla is **** to keep clean too. The silicone or whatever that green stuff is ***** in oil, grease, etc.
I'd have to check, but won't be home until around Thanksgiving.Probably Coil hose Pneumatics FlexeelI, I have it on 3 of my reels.
Good to know. The flexzilla replacement ends are available on amazon.That one has a crimped ferrule.
Pro versions with spiral end are the reusable.
I suggest cutting off the end and replacing with a reusable end in the hose size.
Exactly..What kind of crimps did you use there? Have a link?
I agree. The material on Flexzilla hoses is a magnet to dirt. When left outdoors, it becomes very grimy.Yeah, but oil soaks in and it doesn't clean anywhere near that easy.
Annoying to get coal miner hands everytime grabbing the hose. It's definitely not designed for use in a truck shop. Maybe wood working or something grease free.
The rubber ones do that too. I snapped a fairly new Goodyear one last winter like it was an old dry branch.I only run 100% rubber hoses as the hybrid and pvc junk get kinked/cracked and harden in the -40 winters we get (despite the claims that they can withstand it).
