Air Hose Reel Help
Ren Hoek
Maryland
I have a central pneumatic hose reel. The pull ring attached to the pin that locks the reel broke off (see image), and I'm not sure how to pull it back out. I tried to pull it but I can't grab it. Do I need to dismantle the reel to be able to release the spring that holds it
Thanks,
Brad
R
Ren Hoek
Maryland
Caution- The internal spring is wound tight, be very careful if you decide to separate the halves. I'm not sure if this model has the exact spring setup.
The reel appears to be solid. I don't see away to separate it. there are 3 bolts that go through the center I take those out and see if that will let me get access to the brake pin.
