air/hydraulic jack
Firebrick43
West central Indiana
I have the 20 ton A over H and it will run off my MAC700 compressor (around 3 cfm). If you are running it long strokes you may need to stop and wait for the compressor tank to recover but not terribly long. Its not like a die grinder or air hammer that will not work correctly without flow, it will just take longer
Firebrick43
Just thinking though, doesn't your motorhome have hydraulic leveling jacks? My wife's grandfather had a Winnebago and he just would use them to lift a wheel off the ground to change a tire.
devvar
Connecticut
I run that 12 ton jack of my 2.6 cfm pancake compressor. It slows down on a long stroke but never had an issue with it
L
littleboss
I tried it on my 32' gooseneck trailer. 12 ton HF jack and Bostich pancake compressor. I did have to let it fully charge first but worked ok. Thanks
Carchie
Anybody know if a HF 12 ton air/hyd jack will run off a 4cfm air compressor? Thinking about carrying this compressor and the 12 ton jack in the motorhome. It doesn't have to be fast as long as it works
https://www.harborfreight.com/4-gal...Luk9DfLBt_d6eDAtjMJNRAsVXEkhaLN8aAhXKEALw_wcB
A 4 CFM compressor will run that jack just fine, especially if speed isn't a priority. The jack only uses air in short bursts to pump the fluid, so the compressor will just cycle on to catch up. It's a great setup for a motorhome.
