Tim240Z
http://www.costco.com/Browse/Productgroup.aspx?Prodid=11071422&whse=BC&topnav=&browse=
The Arcan air jack is a compact and rugged alternative to the traditional hydraulic service jack. Once connected to a 120psi air supply, lifting is as easy as pushing a lever. The control valve locks in the air and keeps the jack inflated even with the air supply disconnected. The wide, flat steel base and internal steel support structure keep the jack stable while a powder coated finish withstands heavy use. The air bag is similar to those used in the suspension systems of semi trucks and is designed to provide years of service in harsh conditions. Safety is a critical feature in lifting equipment so we test our products to against the latest safety standards.
Air operated (120psi working pressure)
Control valve keeps jack inflated when air supply is disconnected
Safety valve prevents overloading
Tested in accordance with industry safety standards
Wide flat steel base for extra stability
Two handles for easy positioning
Powder coated finish
1.8 Ton capacity (3,600lbs/1,632kg)
Minimum height 6.5”
Maximum height 17.25”
41lbs
Dimensions 17.8” x 11.1” x 6.8”
2.2 Ton capacity (4,400lbs/1,995kg)
Minimum height 5.75”
Maximum height 12”
51lbs
Dimensions 19” x 12.9” x 6.4”
I saw those too.
The exact reason I went out and bought an aluminum floor jack......34 lbs
