Southernsorrow
- Joined
- Mar 12, 2014
- Messages
- 40
I have a craftsman compressor. had it for years no problems. I noticed a little over a week ago that it was leaking around the aluminum hardline at the tube seal that goes into the head/manifold. so Okay $2 part changed that out along with valve plate + new upper head gasket and lower valve plate gasket No more leaks from that spot anymore.....
But now I go to use it and no air in the tank.... filled the mofo up to 150lbs... and 10 minutes later lost 20+lbs... got out some soap and water and traced the leak to the 5/16 compression nut holding the main aluminum line from the compressor to the tank. The air is seeping out the top of the compression nut around the diameter of the tube. I tightened it down hard and still leaks like a sob.
So do you think the problem would be solved if I just replace the compression nut for $5-6? or do you think I need a new outlet tube which is around $35-$50.FD "friggin dollars" and/or or could it be the $20 check valve ? or all of the above ?
