Air line placement question...
swa240z
Bloomington Indiana
Is there any reason I should not run the main air supply line down near the garage floor (about 12" above the floor)? I have read lots of posts and it seems like everyone runs it high and then drops down from there. For looks, I'd prefer to run the main supply line near the floor and run outlet lines about 42" up the wall. I was planning to add a couple of drop legs to the the main line to drain out any moisture. I'm planning on using black pipe. Thanks!
Steve
zeebad1
Northern Illinois
That's where mine is, and I see no reason to have it anywhere else.
No "up, and then down " fittings to your drops.
Just "tee" up off of the main. Nice & simple.
LutzTD
Lutz, Florida
mines up high because it would be in the way 12" off the floor. I have 8 inch columns every 10 feet along the wall so it really applies for my building. I would lose the space between the columns if I had an air line there
CNGsaves
KS and OK
It'll work but you'll be pushing water in line along ground towards the first "drop" or connection point. Be sure to put water drain at end of that run and have it run downhill.
To get dry air, put your drying equipment between compressor and the airline.
Fixnair
Sapulpa OK
Ideally you should run it high and slope it away from compressor. Tap your exits from the header out of the top, over &then down. That's the driest method.
