Finally getting around to plumbing compressed air to my garage, have a few equipment questions.
The compressor sits in my basement. Ive plumbed a copper line out the side of my house, down to underground, then over to my garage. It goes up about 2' to enter the garage. Basically the high point of that line is where it exits my house. I have that portion of the line pitched back towards the compressor, and will install a drain leg at the low spot.
Im basically looking for advice as to what to install where. I figured I wanted an air line available in the basement, and one outlet to the garage line. I was going to put a regulator on the garage line in the garage itself, so I dont need to worry about guesstimating the pressure I get out there. That stuff seems simple enough. Where Im a little confused is about filters/water separators.
Do I need one IN the basement? Or would a drain leg handle that? I was guessing I definitely need one on the garage line, most likely where it enters the garage? What should I be looking for in regards to the filter....a coalescing? In addition to a coalescing, should I put a standard 5-micron filter on the line coming right out of the compressor? (even before the first regulator)
I dont plan on any painting in the garage, just didnt want to ruin decent air tools with "wet" air. Been looking around Ebay and I see lots of Norgren, Parker, Wilkerson stuff....is any of it any good? Wilkerson seems to be most abundant........dont know if that means anything.
Thanks in advance.
-Chris
Thanks in advance.
-Chris
