I have a couple extra than it takes as it can be brought both directions, its a couple extra pieces hose and 1 reel but makes it so easy but most not in the original design. Some air velocity is all right, keeps it clean. 1/2 the tool use in my shop is 1/2 100 ft. If I was using tubing would have went 3/4 I have 1/2 feeds the sandblaster, happen to have another 25 ft 1/2 so I use it to the pot, I have ran it with 3/8 hose, a lot, a 50 ft reel and I run out of air. I cant really tell the difference, I think the smaller hose is better, it slows it down a little and should turn it down some but I am really done or staging by the time any of it is an issue and to take advantage longer runs would add air from my truck. , changing or upsizing the pipe or hose still wouldnt make any significand difference.
Gets more than it needs now. We could be doing the work from 100 ft of 3/8 hose, more power would be irrelevent 99.99% of the time. little bigger makes it a little better and our biggest load is never beyond 80%, cant even tell 2 operators are on with common tools even if they are on the same circuit. When I am using lots of air it isnt cause I have men going like maniacs but is due to sanding where I can run it out of air unless I turn on the demand if I work hard enough, usually finish before running out of air,,, better couplers, higher flow, more power got nothing to do with it. Can run a comp out of air with a simple old air fitting they been using forever.
My bud a crazed body man uses a common fittng on 8 inch DA, doesnt slow it down. Most guys dont even own one, I dont. The sandblaster doesnt require the largest line, it uses a lot of air but not in bursts like impact and in many cases, maybe most once its sufficient to do the work whats it matter if you can get more? The work in garages is rather intermittent. Air velocity loss mayu be worth it if the load was high enough and running 24/7 but rotating tires, other mechanic work the real hours is few. Sanding some difference but, I got to turn the tools down anyway, they got too much, its why they got regulators on them instead of power boosters.
