Air n tools needed for auto repair
Travinsky
Miami
4 years ago I bought a beat up pickup to learn about body restoration and custom work, but never got around to it until now that I have plenty of time. Can anyone tell me what tools (air and manual) I should be looking for and which compressor cfm rating will be needed to run these tools? I currently have 120 volt in the attached garage.
Truck is rusted, dented and leaks inside the cabin. For many reasons I won't be doing any painting. I just plan to learn about cutting, welding, body work and sandblasting for myself not as a business. Also because I am now in "permanent retirement" this might take me years to complete so I am looking for medium quality tools for a good price, used or new, and made in USA is a PLUS but not a requirement.
Here is a pic of my truck a couple years ago but it still looks the same with badly faded hood and roof. I currently have these parts still in boxes that include a front spoiler, rear steel roll pan, 4x4 fenders and valance to install.
If you know of any good articles/books I can read, it's much appreciated.
K-Dog
Millersville Maryland
you will be using a cut off wheel a whole lot in this project.
That and a grinder for phase one of your project.
A D.A. and a file sander for the next phase.
woody 73
The Great State Up North
Maybe the following can help give you a start in what to look for:
http://www.aircompressorsdirect.com...ick-The-Perfect-Two-Stage-Air-Compressor.html
Sometimes in life you can get by with starting out with smaller type machines but in the case of buying an air compressor bigger is always better; I have never heard of anyone saying gosh I wish I had not bought such a large air compressor, rather the other way around...My unit is not able to run many air tools for my project.
Best of luck.
Askme42
Goreville IL
Not saying the job can't be done but you're not going to do much with air tools unless you have 220. Trust me unfortunately I know. I only have 110 at the moment.
crewchief888
NW indiana
most 110v compressors just dont have the air volume to keep up with air grinders, sanders and media blasting.
what i've done is use electric powered tools whenever i can.
a 4 1/2" electric grinder ( or 3 or 4) will do quick work of panel cutting, rough grinding, and wire wheeling.
a 110v mig welder with .025 wire/ gas will take care of your patch panels.
i use glass bead, a suction type sand blaster and an oiless compressor to do any blasting i need to do.
the compressor runs continuously, and doesnt really keep up even at low air pressures.
i sometimes use a da sander, most of my bodywork doesnt need to be anywhere near perfect on my s-10 blazer trail truck.
there are a few decent quality electric DA sanders available at your local big box store.
just my $0.02
pic attached of some extensive body modifications on the blazer, all done with electric power tools.
:beer:
T
Travinsky
Miami
Thanks everyone but I have good news. Today I discovered my landlord has a 25-amp timer that was connected to a defunct sprinkler pump and her main box has a dedicated 2-pole 20 amp breaker. I looked at the wires and they appear to be 10-12 gauge, I checked the wires and they are reading 244 volts in the garage using a Klein MM100. So now I am looking to get the biggest compressor that will run with less than 20 amps. Any ideas you can recommend?
Also, Woody thanks for all the links.
T
Travinsky
Miami
pic attached of some extensive body modifications on the blazer, all done with electric power tools.:beer:
Chief,
I having been watching videos on electric plasma cutters and tig welders, do you have any recommendations? Lowest price is very important but I hate buying used since I don't know how to tell if it's in good condition, thanks.
