HotRodHudson
- Joined
- Nov 18, 2013
- Messages
- 373
I've been working on setting up my air compressor lines to my 60 gallon single stage kobalt compressor at our new house and I've been frustrated with the small size of the 3/8" port on the tank bung. The compressor has 3.7 running hp, with 11.5 SCFM @ 90 PSI & 155 max PSI.
This morning I thought I'd see if the bung would budge & got extremely lucky that if popped free. So before I go buy a replacement bung with an increased port, I wanted to ask for recommendations. This is the air bung, not the water drain bung.
Here's what I was thinking: 3/4" bung port then run copper. 3/4" copper line to 3/4" ball valve, then to a 3/4" copper tee. One end of the tee would go to supply the main air system for the shop with filter, regulator & rapid air 1/2" master kit. The other would be used as a future need, in case I need high volume &/or full pressure, perhaps a blast cabinet.
