Let me start off by saying I don't know what is required specifically for your vehicle. What I can say from personal experience is I had to replace six airbags and three seat belts that were set off by a front driveshaft failure on my wife's Mercedes E350. I was quite surprised that nothing needed to be done to the airbag control module other than resetting the SRS light with my Autel scanner. Had always understood that it was a very complicated process, even a friend who is a highly regarded Mercedes INDY didn't know if he would be able to reset the module with his professional level scan tools. I actually called one of the "reset" companies directly (unfortunately don't recall which one) and they basically told me they don't do anything to the Mercedes module other than resetting the code that triggers the warning light and that I could do it myself with a scanner that supports SRS reset. Quite an eye opener. Again, not sure if that's the case with your vehicle but I did it myself with just an OBDII scanner on my wife's vehicle. Good luck.
ETA, forgot that I also needed to recalibrate front passenger seat before the error codes could be reset. That process was also supported by my scan tool (Autel 808P). The nine errors for deployed airbags reset after installing new (actually used) ones that were functional. Process was replace the deployed airbags/seat belts, recalibrate passenger seat, reset SRS warning light.
