Aircraft tools
sgtmac
Wilmington ,nc
I work in the aircraft maintenance industry and we use some unique tools and products in our trade that I would like to share.
I have taken lots of advise and ideas so it's time to give back.
sgtmac
Wilmington ,nc
We remove and install a lot of screws #8 and 10s, most are steel but a fair number are stainless too. Needless to say we employ a lot of methods to extract stripped screws.
One of the slickest extractors is available at lowes for around $20.00. The nice thing is its a drill and extractor in one piece. It works great so far but the jury is out on how long the bit will last.
The manufacturer says they will replace any piece that broke fee of charge, I doubt this covers smoked units..but for a few bucks apiece I can charge it to the job.
sgtmac
Wilmington ,nc
We deal with a lot of things held on with glue, typically 3M 1300L. In the auto world I believe it is called weather stripping adhesive.
Some of the things we periodically replace for instance are deice boots, which are large inflatable rubber assemblies glued to the leading edges of wings. To remove the boot you rip the old boot off and in the past we used MEK to soften and loosen the glue. MEK is not friendly to paint or livers so I was pleased to find a new product called Peerco 321.
I was told it is envirementally friendly and does not hurt paint...I didn't believe it would work worth a **** but after a little experimenting it f...ing rocks!!
We applied it in a layer about 1/4 thick and covered in plastic to keep the fumes in, let it sit overnight and the next morning it wiped clean off, glue to. It did zilch to the paint..... This cut our cleanup time into about 1/10 of what we used to do.
It seems to be only used in the aviation world but you can buy it online at Skygeek. I hope the Link works?
[URL="http://www.skygeek.com/peerless-peerc0321-adhesive-remover-gallon.html[/URL]
Mohawk Dave
SoCal
sgtmac,
Thanks! Keep 'em coming. I have been getting into aero tools for the last year. Started with (real) rivet guns and clecos, and now onto drills and nut plates, rivet shavers etc.
(We build off road race trucks, and it amazes me these two industries haven't overlapped more).
Thanks for the info and all future info!
sgtmac
Wilmington ,nc
Spray nozzle holder........It's basically A flexible rubber ring that stretches around the aerosol can and the opposite end holds the straw for easy access and retention. It's sold by Brownells a gunsmith and reload supplier.
U can order online for around $1.00.
Mohawk Dave
SoCal
Lots of skilled guys hear. If I can make a request, I'd like to see/hear tips/tricks for working with sheet metal. Everything from:
drilling and punching holes
bucking bar access
nutsert tricks
nutplates
loctite / other adhesives and effects on Titanium hardware or SS rivets
lock washers/nylock/stover
washers (different types in diff. areas)
threading aluminum tips (size for strength/depth ie.)
QR latches and other locking mechs.
Blind rivets
Tubular rivets
semi-tubular rivets
And of course the tooling you use for all apps.
Thanks!
sgtmac
Wilmington ,nc
Lubriplate! Great stuff..my first two planes were the Catalina PBY and a DC-3. The engines were assembled using that stuff for everything.
skywrench
One of the type-centric aircraft boards (www.supercub.org I think) had a string going this winter on your top ten most-used tools. I'd like to appropriate the idea for this forum. To help clarify, please mention what you mostly work on: Warbird resto is gonna be different than corporate jets, ag planes, single engine G.A., rag-and-tube.
Thanks. Skywrench
Mohawk Dave
SoCal
Well, this is what we work on...hey, it flies, right? :beer: https://www.youtube.com/results?search_query=psychotic+racing
<iframe width="560" height="315" src="//www.youtube.com/embed/AhrDfN1OuJI" frameborder="0" allowfullscreen></iframe>
<iframe width="560" height="315" src="//www.youtube.com/embed/uSbOlqM9pZM" frameborder="0" allowfullscreen></iframe>
Provincial
Near Salem, OR
sgtmac, since you are working on DC-3's, here is a quiz:
How do you do a gear retract test with just one jack?
How do you do it if the jack doesn't pump up?
I did this once!
A_Pmech
IL
This sounds like a story we need to hear...
I'm guessing crib it up, let the air out of the tires and pump like a madman.
I did this once!
James_B
Nova Scotia, Canada (started in Brisbane, Australi
I did this once!
The licensed mechanic that used to work on our "Hangar Queen" (Swearingen Merlin), had a rule:
  • Do not let visitors into the cockpit while the undercarriage ground interlocks are disabled.
Everyone learned a valuable (and expensive) lesson that day.
bsplum
We use large rubber wheels that chuck up in the air drill. Takes about 4 to remove the de-ice boot adhesive per side. 2 hr for light jet.
http://www.amazon.com/dp/B00488DDB8/?tag=atomicindus08-20
Dave455
Sussex, England
My guess: P-80 Shooting Star
That was my first thought too, (basically the same airframe) but it looks like that's got the camera in the nose which suggests T-33. I've also seen quite a few T-33's with those exact markings!
Now we'd better discuss what tools were used to build it before we all get banned for being so sad!
gagreen
Colorado
If your messing with foreign warbirds...
The plierwrench and I become my besties.
And a nice pair of scissors for fabric is always good to have around.
skywrench
gagreen, is that Knipex pliWrench smooth-jawed? I could see how this could come in very handy. Would it replace a Ford wrench?
Thanks. Skywrench
ggoss
Cary, NC
Thanks. Skywrench
I have a pair of those (mine are either 10 or 12 inch, I don't remember). They're Knipex "Pliers Wrench," and are indeed smooth-jawed. They also give you an insane amount of leverage because of the design (they claim greater than 10:1 amplification of squeezing force).
The first day I got them, I tried to flatten a penny with them that was placed vertically between the jaws. With one hand, and not too much effort, it folded completely flat. That, and they don't mar anything up. Highly recommended.
raboyto2
A nice little thing i picked up during my short stint working on aircrafts was when you feel the screw about to strip, (or did strip but not 100%), to dip your screwdriver tip in valve grind paste. I cant believe how well it works. Iv used it on rounded sockets before too with it also helping.
That, and dimond covered PH2 bits works good.
FlyingLow
Vancouver Island
Excellent for squeezing -3 and -4 AD rivets too... A rivets too for that matter.
Yardstore.com has become a new favourite of mine lately.
