Airline
BartPeace
Can Pex tubing be used to supply air? It has a pretty high pressure rating for water.:headscrat
5wndwcpe
Southeastern, PA
Hmmm...... I don't know if I'd plumb that staight out of the compressor though. Remember, the compressed air will be hot at that point and PEX has a good deal of thermal expansion. Also, as the temperature increases, your PSI rating decreases.
BartPeace
I plan to use 1 in sc 80 pvc for the main run into the building. about 20 feet then go to pex. thanks for the input
