SliderJack
Nice work! Would like to see pics of your plane build too!
I'm slightly confused. Nice garage for vehicles but is it intended to fit or build planes?
Ok, cool, makes sense. I did not know the wings were removable. I assume you can trailer it to an airfield? A work friend of my wife's lives on a private airport with the hanger out back of the house and the runway in front of the hanger but they are older 60's homes and in need of repair. So is his plane, an older Chinese 2 seater. The runway is also extremely narrow.
The garage is much bigger than my detached residential one I'm sure.
Well, I wouldn't exactly say "removable" because that implies more of a routine operation. One can remove the wings on this airplane by removing a bunch of bolts and disconnecting the controls, fuel, and wiring; but for practical purposes once the wings go on the last time, that's it. We removed them once on my dad's airplane after it was flying because he wanted to get it repainted, but the process took a couple of days each way.
Now, for building purposes they can be temporarily installed with pins to allow running and rigging connections and making the wing root fairings. That's what I'll be doing. I'll bolt the wings on "for good" once it's at the airport.
That makes a lot more sense now. Easily removable wings are a bad idea!
And it's DONE! Final inspection was yesterday afternoon, no issues. Pics to follow once I finish moving everything in and organizing--right now stuff is scattered everywhere.
After move-in, the next steps are:
- Fix up the garage for my wife to use--insulate the exterior wall and door, add a couple outlets, replace the sheetrock on that wall, paint, and upgrade the lighting.
- Fix the back yard up--fix the grass, expand the patio, add a fire pit and planters
- Add a "driveway" of grass mesh and a small ramp to get vehicles into the shop
I built my RV-7 in 3 different states. The Tail was built in a 2 car garage in Florida, Wings in a 1 Car garage in Texas, and then the fuse and finishing kits and final assembly went together in my Hanger in Olympia Wa. Sadly I sold it about 6 months after flying it to go fly Blackhawks instead. GOOD LUCK!! Its an amazing accomplishment and by far the coolest plane.
That was me. Parked at the end of row right next to some pavilions. I actually sold it at the show to a guy from Chicago. Ended up delivering it 4 months later. I miss it every day.
The Rotax is a decent engine but it's too small for the -7. The airplane's designed around the Lycoming O-360 so I'm going to use one of those (or a clone) with the SDS EFI system: http://sdsefi.com/aircraft.htmlAh, the RV-7...
What power plant are you planning on using?
I fly a Jabiru J-230 and their engine by the same name has never let me down.
My advice: Stay away from Rotax!!!
