Fastbird
How do you think it would look?? Walls are white, cabinetry is white also. Reason I am considering all black is because I work on my cars....a lot. Fluids get spilled, **** gets tracked in, and like any good car, they either already do or eventually will leak. So I thought the all black theme would help to hide the staining and obvious signs of heavy use a little better. I would combat the darkening effect of the floor by installing 6-8 overhead fluorescent fixtures to replace the three single 100 watt bulb fixtures that are in there right now.
At the very best, a white or slate greyish perimeter border of 3-5 tiles width at the most and possibly a short width same colored seperator between each parking spot (3 car garage, 750 SF).
Thoughts?
Thoughts?
It will also be very difficult to keep looking good. Black will show scratches very vividly and your floor would probably end up looking gray in very short order in the areas where the cars drive and you do most of your work. Also, the amount of light you will lose will be very noticable. I do a bit of photography and it is amazing how difficult it is to shoot in a room with a very dark floor.
