The Drill Press – All Metal Tools @ 602-804-9664
www.allmetaltools.com
Anyone looking at this setup, spendy @ $6K. Youtube C&C Equipment was using one.
I had the exact same thought looking at it, come on, you want me to spend six grand show me what it looks like!I think it's odd that they don't have a view of the entire DP, just close-ups. How does it stand up? How tall is it?
Thanks for that RMERR, I take back what I said about tapping with it..that's pretty slick. Just not 6K worth of slickIn case anyone is curious like me here's a very short video
It might be a good drill press but they should find a better cutting fluid than WD-40 for the drill bitsIn case anyone is curious like me here's a very short video
and the mentioned video from C & C equipment (the drill press appears from the 3:30 to about the 8 min mark)
It’s rack a pinion for the head up/down.Looks like someone's pipe dream to me. It doesn't look all that solid and I sure as heck wouldn't want to try tapping with that chain drive set-up. At that price, good luck to them.
Well I’m looking at this on my phone so I had no idea it’s a RnP set up. But I would like to know why you think utilizing motor bearings is such a poor idea. I would think they’d use an angular bearing to mitigate axial deflection, but I don’t know if they did.It’s rack a pinion for the head up/down.
The chain part of a counterbalance. There is a weight in the column that supports at least portion of the heads weight.
It’s actually one part of the machine that is designed ok. A lot of old massive vertical milling machines have a similar setup so the ball screws and. Motors don’t have to support all the weight constantly
It a standard C face motor frame probably a nema 145. They don’t make high thrust motors with die cast aluminum ends which it clearly is nor is there enough meat on those die cast bases to modify for a 5205 double angular contactWell I’m looking at this on my phone so I had no idea it’s a RnP set up. But I would like to know why you think utilizing motor bearings is such a poor idea. I would think they’d use an angular bearing to mitigate axial deflection, but I don’t know if they did.
I wouldn’t take that bet. I don’t have any confidence in their product. I do like the tapping aspect but that real easy to replicate for penny’s on their dollar.It a standard C face motor frame probably a nema 145. The don’t make high thrust motors with die cast aluminum ends which it clearly is nor is there enough meat on those die cast bases to modify for a 5205 double angular contact
P base vertical pump motors that would have double row angular contacts are cast iron and start about 3 hp. Much larger than that. Much thicker end section.
Smaller vertical pumps (and some large ones, use thrust bearings in the pump chair or are special made motors from companies that make the whole shebang like grundfos.
I would bet you a Benjamin that motor has a C3 tolerance 6205 on the shaft end and a C3 6203 on the fan end.
The tapping is easy to replicate with any vfd. I have installed it on (4) series II bridgeports I converted to vfd and my personal DP220. I use a momentary and switch but could easily be changed to a footswitch if desired.I wouldn’t take that bet. I don’t have any confidence in their product. I do like the tapping aspect but that real easy to replicate for penny’s on their dollar.
