Allen-Bradley using JIS screw on 525 conduit boxes
mrborohachi
Berdoo Route 66
I was going to ask if Allen-Bradley uses a JIS cross head screw on their Enclosure Conversions, but I found a picture of an older model enclosure that clearly shows a dot on the screw head. The screws I run into on the current "IP 30/NEMA 1/UL Type 1 – Frame A" do not have a dot.
https://internationalpartssupplyinc...type-1-enclosure-conversion-kit-34661524-xxtl
Amazon has this 30 piece VESSEL made in Japan bit set that I'm buying for work ($32.57). Nice to finally see a T-27 included in a set (needed for Harleys).
VESSEL IMPACT BALL™ Torsion Bit 30+1 PC. Set in SLIDE CASE No.IB31P02U Made in Japan by VESSEL
dnschmidt
Phoenix, AZ
The fact of the matter is that there is absolutely no reason NOT to use a JIS (or the modern DIN replacement of the JIS) on any Phillips head screw as they fit both perfectly. All of my Phillips screwdrivers are JIS compatible. Only American made screwdriver, especially the older Craftsman, don't adhere to the new DIN standard that superseded JIS.
BrandonV
Arizona
The dot is not called out in any of the JIS standards for cross head screws. In fact it was originally put on as an indication that the thread pitch of the fastener was ISO not JIS back in the late 1960s.
I feel like this topic has been beaten like a dead horse. For 40+ years JIS screwdrivers have been roughly compatible with DIN/ISO screwdrivers for cross head fasteners.
As long as you're using a modern quality European or Asian screwdriver you'll be fine. Don't use a 50 year old Stanley.
dnschmidt
Phoenix, AZ
I sold JIS compatible screwdrivers when I sold TOPTUL and all of the motorcycle guys felt like building a statue to me since they were no longer stripping out the screws on their bikes, particularly carburetors, using the old Craftsman Phillips they had inherited from their dads.
lotus_esprit
Just today I removed the semi-seized screws from the flywheel cover of a 2004 Yamaha outboard motor, initially I tried a brand new Snap on Instinct Soft grip no3 cross head screwdriver, purchased last week, however it was a poor fit in the screw head; swapped to a Vessel no3 Impacta, fitted perfectly and did not try to cam out or slip under load. The Snap on is visibly a poor fit in the Yamaha screws.
The Cobbler
as far as Craftsman Phillips, not to derail this thread, but I never found them a very good fit on a phillips , even when new they would easily cam out. and that's from tools in the mid 70's
Sumboodie
AK
So there's Phillips Phillips and Phillips JIS?
There flat JIS too?
BrandonV
Arizona
I have no clue what Snap-on makes their tips too. They could be an older profile considering it is an American brand.
Anything marked PH on the screwdriver itself is usually an indication its a DIN/ISO screwdriver per the marking being required per the standard and should fit a JIS screw well.
Foreign screwdrivers are almost 100% going to be DIN/ISO. Look at Amazon Japan. The top sellers are not Vessels they're German, Chinese, and Taiwanese brands.
BrandonV
Arizona
There flat JIS too?
Most things we call Phillips screws are referred to as "cross recessed head screws" in the standards world. As with most things, their dimensions can vary from one standard to another.
It's important to note that the standards provide a range of values that qualify as compliant. This means you could have a screwdriver at the edge of one standard and a screw at the edge of another standard, resulting in an overall very sloppy fit.
KnurledNut
n/a
Snap-on is a licensee of the genuine Phillips Screw Company standards, a private company with their own specifications for drivers and fasteners that are designed to match.
Phillips is typically used as a generic term since it's so common, but it has been a licensed technology for decades.
Thus the registered trademark symbol.
The same goes for Pozidriv, its also a PSC technology.
BrandonV
Arizona
Not sure how that works with the original Phillips drive anymore. I haven't seen the old style Phillips advertised as a licensable technology for a long time.
Their use of the registered trademark logo is really just following the USPTOs recommendation of clarifying that they/Snap-on doesn't claim exclusive rights to the term "Phillips".
KnurledNut
n/a
Whats not to understand?
You want genuine Phillips, you pay for the rights.
BrandonV
Arizona
Milwaukee uses the term Phillips without any registered trademark (which is seperate from any licensing) what so ever on the packaging. Nobody is licensing classic Phillips anymore.
ajchien
Los Angeles, stuck on the 60 freeway.
FWIW, A few years ago I realized that my craftsman screwdrivers are a mix of Pratt reed and western forge. Turns out that my PR drivers work with JIS while the WF do not.
