Bubba Fett
I think a lot of screwdriver brands did this as well.Member @RoninB4 worked for Eklind and has stated they lowered the HRC for liability reasons so the keys twist instead of break.
In the case of most of his tests, where he "torture tests" tools until the tool itself breaks, I would agree with this. Maybe the test doesn't give you the whole story, but it gives you some useful information.The tests are not perfect. But it is a lot better than the 'feelings' circulated online. Before anyone comes up with a better test, this is the best evidence out there.
That just means the tests are not perfect. Randomness always exist. As long as he didn't rig the test to use loose fitting fasteners for some and tight ones for other wrenches, it is fair. Just a bit random. But given consistent patterns other noticed, see post 86, this randomness has limited impact.In the case of most of his tests, where he "torture tests" tools until the tool itself breaks, I would agree with this. Maybe the test doesn't give you the whole story, but it gives you some useful information.
In this particular test, without knowing that the fasteners he's using are within specification, then when the fastener rounds out (which it did for basically every brand) you have no idea if it was because the Allen key was off-size, or if the fastener was off-size, or some combination of the two.
Without knowing this key information, the "max torque" part of his testing is 100% useless IMO. For all we know he could have tested one brand in a fastener that was +0.1mm and another that was -0.1mm, which would give extremely skewed results.
With Allen keys, the main difference between "good ones" and "bad ones" is the sizing and tolerancing. A cheap set might have one that's right on size, and then another one that's 0.07mm small. That one that's 0.07mm small will be much more likely to strip out a fastener.That just means the tests are not perfect. Randomness always exist. As long as he didn't rig the test to use loose fitting fasteners for some and tight ones for other wrenches, it is fair. Just a bit random. But given consistent patterns other noticed, see post 86, this randomness has limited impact.
