Allen Wrench Problem
JoeyO
I recently purchased a new motorcyle and it uses large Allen wrenches then the set I have to put into my screwdriver/ratchet set.
Now I have a larger Allen wrench set but I normally use a torque wrench. So I can't use my Allen wrench set.
I've noticed that Craftsman (who I usually buy tools from), doesn't sell a set that I can use. I've tried cutting one of the allen wrenches (the 8mm) off so that it's straight so I can use it in my ratchet. Unfortunately it's good and hard and will take way too much work to do that too.
My question is this:
Should I buy a cheap set of allen wrenches and then cut off the 90 part so I can use them on my ratchets? Or does someone have a better idea?
Thanks in advance,
Joey
Kevin54
MEMBER EMERITUS
Urbana, Ohio
The Allen wrenches will cut easy but you need a cutoff wheel to do it. Also depending on what you want to spend, NAPA, Advanced Auto sells allen wrench sets already with their own sockets. Along with Grainger and a host of others. And a sure fore bet to get a set is Snap On, or Mac.
eschoendorff
A torque wrench with the proper sized hex bit socket on it should give you a good reading. Do you think it may not?
Agreed. There is no reason that the reading should be affected simply because you are using a hex socket. Now, if you apply the torque a different way, or add a swivel or something, then you will run into inaccuracies....
