Altering existing 220 for compressor/welder
sevanseriesta
Last year I wired my garage for my new welder with a 30a breaker. It uses a different plug then what my compressor that I just bought does.
The compressor says 220v at 20a
Its an older compressor, craftsman 4hp 220v 20 gal tank.
So my question is:
Should I or can I use the current wiring for my welder with the compressor?
Can I just switch the plug on the compressor? Or should I run the wires from the welder outlet to a new outlet for the compressor?
I would like to do it right but also the cheapest way possible.
RickP
Annapolis, MD
The easiest way to go is an adapter, if you can find the right one.
Similar to this: 50A to 30A adapter
Otherwise you can swap out the cord/plug on the compressor to match the welder.
sevanseriesta
Thanks very much that is what I was wanting to know. I was not sure If I would be able to use my 30amp breaker or not.
