Hey guys, i'm back on the idea of getting a rolling or sliding bridge jack for my bendpak hd7p 4 post lift.
Problem is that 2-3 years ago you could get it for $950 shipped.
Now, it's pretty much $1200.
On top of that the car I work on most is my foxbody mustang.
Best jacking points is the subframe connectors. The floors and pinch weld are pretty fragile so I prefer to only jack up from the subframe connectors
I don't think the rj45 goes that narrow and appears you need a pedestal kit that goes on the center bar for another $300.
The subframe connectors are just about 31 on center apart.
If that is how it is, i'd be in this thing $1500.
I'm by no means cheap, but with a 1 year old and a bun in the oven, the $950 i planned on spending was already stretching the toy fund. I don't want to add a third to that number.
I've seen other slide jacks for $500 to about $950, some of which go narrow similar to this one: http://www.completehydraulic.com/lifts-bridge-jacks-clsbj4.html
Any thoughts?
I'm not going to use it professionally, so the manual pump doesn't bother me. Says it had protection for sliding although i read here the sandpaper painted ramps may make it tougher to slide.
I have the jp3 jacking tray already and i don't love it. I had to have it modified by a friend because it wasn't level with the runways because the jack stands need to be half on half off of it. I also had him weld a rail on because i didn't trust the stands weren't going to slide off. It will be good later with a bridge jack, for putting the stands on, but as a jacking point, i just don't feel that safe.
Any thoughts?
