Aluminum Trailer build thread
Robert Haas
I needed a well built light weight trailer that I can pull behind my TDI VW Golf and or my 2006 Honda Goldwing motorcycle,...yep I want to pull a trailer with my bike.
This trailer will be used as a motorcycle hauler, mostly my dirt bike but occasionally I want to put a sport bike on it for the occasional track day. I can not Imagine much things cooler then to pull up at the race track with my race bike being towed by my GoldWing.
I have built several trailers in the past out of steel, this time I want to try my hand at aluminum. Starting with a small sketch to calculate the amount of material I will need I dove right in.
main frame will be made out of .250 wall 4" x 1.625" channel
lay out is key to this build, pre cutting all holes on the perimeter and cross members while it is flat on the bench sure speeds this stuff up.
this is a 15" Makita chop saw with a carbide tipped blade, cuts aluminum like butter
this is the tail lights that I pre cut the holes for
bad_idea
Pasquotank, NC
Have you welded aluminum before? I HATE welding aluminum, mig or tig. It is too easy to have a nice looking weld with zero strength.
R
Robert Haas
As far as welding Aluminum, I own a Miller 200 amp Syncowave but it just does not have the horsepower to do this heavy of a job so I will be using a spool gun on my Miller Mig. I have tested to destruction welds on this exact material before I began the build to assure myself that I was able to build this project to the strength and quality I require.
So going forward here. Once the main perimeter and cross members were cut and punched I built a level flat and square fixture to build on. (Basically a piece of 3/4" Melamie with a 2x4 frame screwed and glued underneath it siting on a set of saw horses on a level slab) The advantage to this is I can clamp the material down and hold it flat and square.
This view shows the perimeter going together.
Cross members going in The lumber laying on the table was temporary spreaders to keep everything straight.
the double cross members are located where the suspension will be mounted up later.
the main spine is a 2" x 3" .250" thick wall tube that will penetrate 3 cross members and terminate against the last cross bar.
the tongue side plates are reversed to place their flat side to the outside as it will be where the landing gear will mount later.
R
Robert Haas
For suspension I will be using torsion bar spindles. They offer a nice ride as well as being simplistic to use as long as I engineer a good structure to mount them to.
a third piece of channel welded on the flat side down and welded to the other cross members takes care of the mounting point.
R
Robert Haas
The plan will be for this trailer to have a lockable storage locker under the rear floor. To make that happen I needed to add a couple longitudinal pieces to the area behind the axle mount. this will support the deck when a bike is rolled on to it and will further strengthen the tail from deflecting.
one of the things I do on all my trailer builds is place caster wheels on the rear to prevent the trailer from dragging in and out of steep drive ways. So I used a piece of 1/2" thick plate as a mounting point for the caster.
this shows how far it will protrude
I fabbed up a floor for the bottom of the locker and welded it in as well as put in the walls around the caster pockets.
... main frame will be made out of .250 wall 4" x 1.625" channel ...
... the main spine is a 2" x 3" .250" thick wall tube that will penetrate 3 cross members and terminate against the last cross bar.
Why the difference in tubing size between the sides an the "main spine" ?
EDIT: I missed the fact that the sides were channel not box !
Smart ! Very Smart !! A good jig/build table always helps make a quality job ! :thumbup:
What are your spindles rated at and what size tires are you using ?
If you don't mind sharing, what did the basic materials cost ?
Jagmandave
Overland Park, Ks.
Caster wheels are a great idea!
How will you compensate for weight front to back so you don't get too light or too heavy a tongue weight?
What will your final weight be? How will that compare to a steel trailer or a commercially built aluminum motorcycle trailer?
R
Robert Haas
Time to flip it over and start the top. 3/16" aluminum diamond plate will make up the deck. I will be using Aircraft logistic cargo track as the heart and soul for the versatility of this build as you will see.
so this is the inside of the locker, three nice bays that will be very useful.
The landing gear I mentioned earlier needed a bolt on mount so I just built one out of .250" wall plate
Here you see the aircraft logistic track and the diamond plate. I welded down the track.
lighting and wiring going in in this shot.
R
Robert Haas
I wanted to "penetrate" the cross members to maintain integrity and strength
Spindles are rated @ 500#'s each the tires in these pics are not the final size will be using the tiny 8" wheels however full size class 3 bearings to compensate for the higher temperatures due to the elevated RPMs
Cost all in will be around 800.00 not counting consumables or labor.
R
Robert Haas
using the old 33/66 ratio for sing axle trailers with 66% of the trailer measured from the ball to the axle.
Weight will be less then 300 LBS
R
Robert Haas
this brings me to finishing off the deck and the lid to the locker. pretty basic just cut to fit and install some off the shelf tool box latches sourced at the local truck/trailer outfitter about 12 bucks a piece. They fold flat and you can step on them with out hurting em so perfect for this application. Inside the locker I welded in the cut offs of the aircraft track so I can store the removable tie down cleats when they are not in use.
This brings me to the fenders, now due to the fact I am running little bitty wheels stock fenders are not easy to come by, however I did locate some that were close in dia. but too damn wide. So I decided to just use some old hot rodder tricks and section them
A piece of aluminum clamped on as a straight edge
break out the plasma cutter and cut these suckers up
half way done
R
Robert Haas
Now just tune up the cut a little bit using the same straight edge as a guide
then tack weld them together.
more tacks (must keep the heat down)
continue tacking them together.
R
Robert Haas
The tacks will become a continuous weld that I will grind flat and metal finish these, no filler needed.
Imcrazy
N. Texas
I would be curious where you find your best source of raw materials. I would like to make some aluminum trailer ramps but wouldnt know where to start looking for the materials.
R
Robert Haas
Local steel yards stock all the Aluminum I used in this project.
Cool indeed, after your amazing build ! You need to spend a bit of time polishing that aluminum and then give it a shot of clear, maybe polyurethane ?
Stick with a good "high speed/high temperature" synthetic grease and you won't have any bearing/spindle problems.
Did you actually do any load calculations on the material (thickness, channel vs. box) or did you just go "rule of thumb" ? What Al alloy, 6061 ? What temper, T6 ?
Muggzy
Orange Co., NY
REALLY nice build. I love the casters on the back since I have a steep driveway myself. I'm gonna have to add some to my ATV trailer :beer: Great use of space with the storage boxes too
I would be curious where you find your best source of raw materials. I would like to make some aluminum trailer ramps but wouldn't know where to start looking for the materials.
There's a company I use from time to time called onlinemetals.com they have pretty good customer service and very reasonable shipping rates
R
Robert Haas
sorting out some of the details here
matthew_turner
very nice!
Sorry if I missed it - Are the storage areas sealed or did you put in drain holes?
Where did you source the axle,...?
R
Robert Haas
Tires are DOT highway rated.
Locker area will be water tight, as well as upholstered with a tweed lining.
Started working on the ramp today. 3/16" aluminum 7' long. it has a couple lugs in the trailer end that lock it into the logistic aircraft track on the tail of the trailer so it wont slide off when in use. Still need to fabricate a spring latch that holds it from falling out.
It stows into a track underneath the trailer.
I cut a hand hold into the bottom end of the ramp so I can grab it and pull it out.
The ramp is 1/2" narrower then the license plate, the license plate will be spring hinged to hide the ramp when it is stowed.
R
Robert Haas
The Baxley wheel chock locks into the Logistic track and can be removed in seconds no tools needed, same goes for the fuel jug cage I welded up.
one of the intended tow vehicles my 2013 VW TDI Golf
