jJon G
Hi G/Jers
I just bought a USED aluminum 8.5 x 12 Snopro trailer with a black clamshell top. The trailer is 4 years old. You can view the exact one on this site they have it called the XR series clamshell http://www.mainesnop...xrt-xtreme.html
I bought the trailer knowing that it had a split beam. The P/O had the trailer on the road when it split so he brought it to a shop to put a patch repair on it to get him home about 8hr. this patch consisted of two plates on each side of the beam as you can see in the pics. after the 8hr road trip the out side patch has split 3/4 of the way down.
The trailers main frame consists of two rectangle beams that the cross stringers for the deck sit on. Two long bolts go through the beam and attach the axel to the trailer. The drivers beam has cracked in the center where the bolt goes through, causing the rear of the trailer to drop. I am thinking that this was caused by OVER tightening the bolt by the factory causing the main beam to squat and weaken then split at the weakest point.
After showing the trailer to 4 trailer dealers today (not the one this trailer was bought from) and this is what they said:
The beams are too slight not the right thickness wall to be used as main beams holding an axel.
The axel that is bolted to the beam is centered in between two cross members providing a empty space that if weak, over time the axel tries to push the beam up into this space.
The over tightening of the bolts changed the structural integrity of the beam and caused a week point.
As for tilting the trailer it was designed to tilt …..
This trailer was not abused and only used in the winter for the sleds two 500ss shorty’s at that, sure it got a bubble bath a few times a winter to get the cra# off of it.
I have had a home built steel job, factory steel job, factory galvanized job, and then this Ugh !
My plan is to take the clamshell and the deck off, flip the trailer over onto a second trailer take the axel and tow bar off and cut the two beams out.
Then bring it to a welding shop to get them to put two new thicker beams in.
I am going to rebuild this trailer so every thing is new or has been checked and serviced.
I just wanted a second opinion on just putting thinker beams in, or should I get some angle stock and plat the new beam where the axle goes ?
Any suggestions or comments welcome
Thanks Jon
Thanks Jon
