Well I decided to go ahead and drill out the bolts. As soon as got them out the jaw started to move a bit.With a little acetone and atf mixed it became quite free. The pin I thought held the swiviljaw to the static body was not it. That was the one I had said had the factory crimp on both ends. Wrong like someone else said they looked like a tap.It was one on each side. One side I was able to use a punch and then vise grips to remove it,the other side I could not budge. They were used as stops to stop the jaw from swiveling. I guess that didn’t work so the bolts or pins went in. I found the proper pin that he’d the jaw in and tapped it out quite easily with a punch.With a little extra work the jaw came out.The one tap that I couldn’t remove gave me a little problem but I persevered and out it came.There may also be tap broke off in the hole for the locking pin on the back of the vise. Strange I could not see any treads. I wonder if they just stuck in there in place of the regular pin and it broke off?
