Am I a part, or a tool? (whatsit)
OldnSlo
Arizona
Dug out of a roller cabinet with clearly just random tools throughout, and no central handyman theme, this has stumped both Google lens and myself.
7.5" in length, 2" length on the business end. Nicely chromed, not hammered on. Appears to be for hand use. No makers mark. Very heavy.
Got a clue?
O
OldnSlo
Arizona
Thanks @APEowner, while I truly don't know what this is, I do own nearly every tire (bicycle/motorcycle/car/truck) tool known to mankind, so this stumps me. I'm thinking no to spoon (too thick, not long enough, typically not polished chrome), no to spoke wrench (too deep, no ****** size marking). So I am thinking its purpose is around bending something that has a narrow flange height since the back end is machined flat to accommodate a perfect 90d bend. All sides (front, back, left and right), are perfect 90d angles. Perhaps to bend something that should not be marred?
^ my first thought was "piano tuning", but that uses a completely different kind of tool.
Best guess: that thing is for adjusting something really expensive.
rlitman
Long Island
Is it chrome, or polished stainless? If stainless, perhaps it's some specialized surgical tool?
RMERR
Northern CA
I was leaning the same way the minute I saw it. When orthopedic surgeons are placing a metal plate in surgery to fix a fracture, they'll often need to bend the plate slightly to align with the bone contour. You can't really tell exactly how much bend until the bone is exposed. A tool to do this is part of the whole set of surgical tools brought out in the OR. This tool looks perfect for this task, slide the plate into the slot and put whatever bend is needed into it. Here's a couple that's vaguely similiar.
MongoTA
CT
Got a clue?
I have a shop-made tool, similar, that I use for sheet metal work. I don't use it to make a bend, but for tweaking bend angles made in a brake or with a handheld seamer. Gets a fair amount of use when fabricating metal drawers or boxes and adjusting or holding corner folds.
JradM
Alberta
Similarly, I thought sheet metal tucking fork. It's not that, but could probably do it.
O
OldnSlo
Arizona
Adding more detail here, it is magnetic. Now, SS can be either magnetic or not, however it is really difficult to discern if chrome plated or SS. I'm leaning towards the medical tool presumption. While it could be used for a disc rotor bending tool (in the bike industry), it looks nothing like what is on the market now, is way too heavy for bike use, and those bending tools typically have 2 or more angles of approach.
@slowtwitch73 , the handle looks like it could be a tire spoon, but is way too thick and wont offer a thin approach to a bead.
@RMERR, I think you have the right approach. A bone plate bender. My image search didn't come up with an exact match, but that's what I'm thinking.
O
OldnSlo
Arizona
Another data point are the grinding marks showing underneath the chrome plating. It's feeling like this was NOT machined on a CNC, but on something more primitive. Again the weight really throws this off as being a tool. It's surprisingly heavy, leading me to think it's a handle for something needing heft. A door handle of some type?
PelicanPines
That just gave it to me... It's a frying pan handle for cooking out... you hook the slot onto the pan and lift the pan.
david3921
Wyoming, Michigan
Trapping tool? A little down this page shows a similar tool.
2oolhound
BC Canada
It looks like a bending fork to me. Blacksmiths use them and have many sizes but they use them sideways compared to that one. That one looks like it's made to push down on with the thumb and it's tiny so I agree it's for sheet metal or medical use like what was suggested.
