cbracer
I have a 20' x 20.5' garage which is screaming for a new floor. Problem is I can't decide what to do. When I bought the house the garage had been turned into a room with carpet and a carpet pad on the floor. After tearing it all up, here is the list of issues with the current concrete floor:
I've done a bunch of research and here's the key points that have limited my selection and made deciding very hard:
So that leaves me with a few options:
Are there any other options I haven't thought about?
- major cracks spread in each direction
- patches broken up where carpet tact nails were used
- unlevel, worst in corners up to 0.75" difference
- some whitened areas looks like moisture damage, florescence?
- I don't want any patterns that prevent a chair from rolling nicely. Most interlocking type flooring has a pattern of coins, ribs, diamonds all of which make rolling very hard. Tile isn't bad because the grout lines are few and far between, which I can live with especially the larger 18" tiles.
- Epoxy coatings will eventually crack given the condition of my base concrete. Even if I fixed all the cracks and leveled the concrete. I've seen a neighbor that had epoxy done professionally and his ended up cracking many years later.
- I don't want to spend $3-$5 a square foot, so most high end interlocking tiles are out. My budget is no more than $2 a square foot.
- Anything that takes 3 days of skilled labor/knowledge is simply out of the question. Something that goes on in a day or two at the most. After doing all the drywall taping, mudding and texturing of my garage myself I can appreciate the reasons for hiring professionals.
- Perhaps that polyeuea / rocksolid stuff that goes on in one day and looks like epoxy might be a good choice. It's more flexible than epoxy so it likely won't crack as easily. The only downside is the quick 20 minute set time which would require about 4 concurrent people applying it. Prep work is less and not having to hire professionals make this one choice.
- Roll out mats. Something durable enough for jack stands? Likely done for a good price and easy to change out later on. I've seen some non rubber type mat materials that are very durable and nothing like old rubber mats.
- I've seen smooth interlocking rubber tiles. Though rubber isn't my idea of strong enough for jack stands.
- Porcelain tiles would be a good option. Would take two days but is something I've done before. I'd be a little worried about getting them all level. I wouldn't want to put in a workbench and find it bounces around like that dinner table set outside on uneven bricks....
- Some sort of Armstrong Commercial flooring? Have seen some examples but there isn't too much information out there.
s without seeing what else is wrong with the floor.
