I have an old pole barn with a quonset hut like wall i'm using as an automotive shop. Over the next summer i plan to insulate the shop and id like to add a ceiling to the bottom of the trusses. the truss span is 6ft on center. my plan as to use osb as a ceiling and then blow insulation on top of that. my issue is that there is probably going to be a good sag being 6ft on center. and the added weight of the insulation wont help. whats the best way to add this ceiling? and will these trusses hold the weight. there is virtually no snow load (snow doesn't stay on the roof) due to the steep angle of the roof pitch and the curve quonset shape.
or plan B Insulate the inside of the roof and then just use plastic 4 mil sheathing stapled to bottom of trusses to keep the heat to a smaller area?
what should i do fellas?
pic of shop in next post
