Amazon: channellock 3017 needle nose
SchillerM
Portland, OR
It showed up as $15 in link, the $9.99 is under "More Buying Choices".
Thanks OP. I have been looking for a good deal on good needle nose, missed all the Knipex and CL sales at Lowes.. This will work!
Matt
LandR
Go to other buying options and select the item sold from amazon. $10.17 for me
elronin
Hialeah,Fl
Holly **** If you look around alot of them are at 9.99 from amazon under more buying options. Yezzz just spent more money.....
www.TheToolReviewGuy.com
Just spent 26.06 on a 911 cable cutter, 209 oil filter plier, and a 528 8 inch slip joint plier. free shipping + 1.11 in amazon reward points.
MJB24
Minnesota
I bought the 8" needle nose and the cable cutter with some Discover rewards I had.
I am usually pretty good about not buying stuff I don't need. But I have no idea what I will do with the cable cutter.
sks
Cut cables, duh! ;)
m4rkz0r
Texas
Cut cables, duh! ;)
EXACTLY!
My boss has some Matco ones that look similar; I use them for cutting battery cables to replace terminal ends. I've used a cutoff wheel to do the same thing, but that's not as safe... Especially when you decide you don't need to use pliers to hold the cable because that takes 30 seconds longer (I mean it's only a copper cable right?) so you use your hand, then the wheel jumps and slices your finger open.
What I'm getting at is; if you buy the cable cutters, you won't slice your finger open.
mudman63
Great deal! The Channellock 9" oil filter pliers are $9.99 as well on Amazon.
EdJack
Picture of Amazon specials - $6.99 slip joint pliers, $9.99 needle nose, and $9.99 diagonal cutter.
mattmus4357
Land of Oz
I ordered the 10" tongue and groove, 8" slip joint, and the 8" long nose pliers yesterday. The 10" showed up today and the others are estimating November 5th-18th. Anybody else have the long estimate?
