darrowco
Los Angeles (California)
ATC
VA
BroncoAZ
I bought one of these back in 2016 for $43. This one uses one input to feed all 12 circuits. The one posted in a link above is split, with one input to feed 6 circuits and another input to feed the other 6 circuits. So depending on your need, this one may be a better fit.
I saw that one was an option as well. I’m not sure if it’s ABYC approved to run a jumper wire from one zone to the other on the split fuse block, but that was my thought process when I ordered. I went ahead and ordered two of these. Maybe I’ll send back the split ones as I typically run the bilge pump wires direct to battery.
PlantItDeep
Try this...
Should be $8.24, black, on/off version. I just ordered a few, will use on the RV and tractors.
I'd prefer red, but those were around $25 each. Still a smoking deal.
Mike
These are a super good deal. I last bought some 9003E (same idea but slightly higher amperage/different size) for $40ish a few years ago and was happy with those prices at the time! I bought a few of these here, sure I will use them soon (I use these normally for batttery disconnects on tractors)
ching0n
I usually get 2/0 from TEMCO
prices vary a bit, but you can usually get at about $3/foot (it is higher now but I expect it will slide back - at least it has in past)
6 gauge is normally about a buck a foot
the 40+40 looks like a good deal. I grabbed the 8awg quoted because of silicone jacket and price for short run typically commands a high premium.
andypress
Good find, Blue Sea Systems is pretty much top-of-the-line for unsealed DC power distribution.
mikeinri
Try this...
Mike
My box arrived yesterday (haven't opened it yet, but should contain 5 of the black on/off switches, which were down to $8.24 on Monday (but are now up to ~$27).
Planning to use 4 (RV, backhoe, 2 small tractors), and have 1 spare. Still wish they were red, but couldn't resist the $8 price!
Mike
hobie18
Can they be marked, painted or even dyed some?
Would not be the same as the marine ones, but could help it stick out.
mikeinri
Maybe? They're mostly plastic / resin.
Up until I started to see the black ones inside of newer RVs a few years ago, I'd only ever seen the red ones (usually on boats).
Mike
ching0n
bobg03
conway sc
Making some de-rusting solution (i think the baking soda was 1$/lb):
Pfizer used to manufacture Citric Acid in Groton Ct, came in 50# and 100# bags...We also used it for washing manufacturing vessels.
