BobsYourUncle69
Westchester New York
Arrived. Here it is pictured next to the 4inch I bought almost 2years ago. Been one of the biggest surprises when it comes to cheap tools. Let's hope this one follows suite
Update on this. Unlike my red 4 inch one , this one does not have a variable speed trigger.
It bigs me because it makes it harder to oil as I run my red one slowly after oiling but this one sprays it everywhere.
jayemm
up high down low
A review on another one of that company's product said it was NOT UL or ETL approved and internal wiring was only 18awg. I would not recommend it just based on that. That other product is listed as 20amp as well (outlets on the unit are 20amp looking, cord is not a 20amp plug)....and lots of reviews are free product Vine reviews.
A few months ago I checked out Amazon while looking for a power strip or surge protector and found that many didn't have any certifications or meet standards and looked sketchy. I think a couple of reviews had pictures showing a melted built-in USB charging port. But they were cheap. I finally settled on a 6 outlet Eaton/Tripplite surge protector with C/ETL/US/Intertek listing. Has max total rating of 15 amps with resettable circuit breaker. Cost a little more but don't think it'll catch on fire. There's so much sketchy **** on Amazon you really have to pay attention. And then there's the Vine reviews.
pcrov
Ontario, CA
pcrov
Ontario, CA
18 AWG with 20 amp plugs? How can they even sell that?
Wrong product. (Presumably one without 20 amp sockets.)
But anyways, mine came today. I picked up two. They're nice solid power strips. Aluminum housing, decent size and outlet spacing, and I'm really liking the angled outlets and mounting options (bottom and back.)
And for everyone freaking out, here's the guts:
Sure looks like AWG 12 to me.
Luckily the deal is still going on, I'm picking up a couple more.
njc41980
Idaho Falls
Thank you.
. . . . . . and also, my wallet hates you guys.
rawen2
High Desert of CO
For the liver who has everything:
$70.90 VEVOR Alcohol Still 8Gal/30L Alcohol Distiller Stainless Steel Distillery Kit
Note: Only ships to Kentucky and Tennessee. LOL!
burger
Erf
I have no idea where I'll use this. But after I saw the insides, I was like, I need one of those. Damn this thread. I love this thread.
2manytools
Mt Pleasant, MI
Any UL or ETL certifications? I think I'm ordering one either way, but curious
Ohio Andy
Columbus, Ohio
What do we think the equivalent AWG is here? It looks like there's nothing there!
I think you would need to calculate the cross-sectional area... So if you know the minimum width and you know the thickness you can calculate an approximation
18 AWG: 0.82 mm^2
16 AWG: 1.31 mm^2
14 AWG: 2.08 mm^2
12 AWG: 3.31 mm^2
ER70S-2
18 AWG: 0.82 mm^2
16 AWG: 1.31 mm^2
14 AWG: 2.08 mm^2
12 AWG: 3.31 mm^2
Yeah, mine is coming tomorrow and I plan to measure it. The odds that I don't return it are not looking good.
Etchase
Hawaii
I think safe current carrying capacity is dependent on material, heat dissipation, ambient temperature and probably other factors. Codes for in-wall conductors are codes. Maybe someone should start a thread on outlet strip safety if they find it interesting, or the value of UL or EU labels? I purchased two of these strips because of their diagonalform factor.
This might be junk, but i wont post about its quality until i get one, but it seems like a deal:
Compressed Air Duster, 150000RPM Electric Air Duster with LED Display & Brushless Motor, 4-Gear Air Blower Rechargeable with LED Light, Cordless Turbo Fan for Computer, Keyboard, Car, Home, Outdoor https://a.co/d/08cPom3P
Use this code for an additional 45% off which may have limited availability: 3UCVRYE7
BuyMyGarage
MIchigan
2manytools
Mt Pleasant, MI
Mine arrived today, 7 days early, no packaging, they wheeled it off the 26' box truck, rolled it 100' to my garage and drove away. Perfect!
I'm thinking they dropped yours off right before mine, if you're near GR.
Amazon did notify me this morning it was out for delivery, which I was not expecting.
Not sure who was going to try to double stack these 😂
BuyMyGarage
MIchigan
Ha, near Flint, so probably no. Looks like you had a pallet, I did not, they just rolled it through the snow.
ATC
VA
Project Farm did a test on air dusters if anyone is considering one:
MichaelP
IL/WI border
Thank you. For non-commercial accounts it's listed as non-available.
Do you know if the same person can have both accounts separately?
moemc
Could plug a 1500w space heater into that power strip and measure voltage drop. Check thermals for hot spots after 30-40 min. Tell ChatGPT your findings. Those perforations are concerning at first glance, but I admit I have never opened one of my power strips to inspect the build. I really like these 2 Klein and this 1 Ridgid powerstrip I picked up recently.. but that corner shaped Amazon one is super cool for particular installs like their examples show.
Their rendering also shows the perforations. So at least you know that is a design intent and not something compromised during production.
ER70S-2
$12.99 CCCEI Corner Mount Angle Power Strip 8 Outlets 20Amp Metal
I got mine today. The ground conductors are 0.32mm thick and the width at the holes is 0.71mm. That is a grand total of 0.45sq mm and equal to an AWG between 20 and 21!
The hot conductor has holes in it, too, but this conductor is 0.45mm thick and the width at the holes is 0.71mm. That is a grand total of 1.18sq mm and equal to an AWG of about 17.
Not only that, there is a capacitor on the switch with a piece of heat shrink over it that was never shrunk. The hot and neutral wires that are connected to the switch are soldered. Isn't that a no-no? I always thought that you wanted them screwed down or crimped so if they heat up, the solder just doesn't melt.
There are so many holes in the conductors. All amps drawn by the eight outlets go through two tiny pieces of the hot conductor at the final hole with an equivalent gauge of about 17.
bluedog225
Texas
Good info. thanks!
MichaelP
IL/WI border
If the holes in the hot strip do not play any role mechanically, you can just fill them with solder or solder copper wire/strip jumpers (bypasses/shunts) over the holes. Even just building up the thin areas at the holes with solder would work to bring the cross section value up.
Ground strip can be built up a bit too, although it may never be needed (hopefully).
That is if you really like the form factor and don't want to return the power strips.
Brandon_oma#692
North West corner of Illinois
Please leave a detailed review on amazon to let future buyers know.
Now I am curious what other ones look like inside.
Etchase
Hawaii
What would the temperature rise be around that hole in the uninsulated bus suspended in air inside a large aluminum enclosure with a 20 ampere current. Is it excessive? What gauge would an extension cord need to be for 20 amps if it was 30 meters in length. What about an extension cord less than a millimeter in length? What’s the wire gauge of that 60 amp wall wart cell phone charger?
