Amazon Warehouse Deals
D
Duker
Livingston, TX
Would make for a nice machine/task light..
Reliable 3000TL Uberlight LED Task Lights 26" Commercial C Clamp With 1.77" Opening, 2 Light Settings, Honeycomb Anti-Glare Lens, Heavy-duty Swivel Joint, 60,000 Hours Of Use, cETLus Certified
https://www.amazon.com/gp/offer-listing/B00AYE8AFY/
Sent from my iPad using Tapatalk Pro
D
Duker
Livingston, TX
With a name like KUNGFUKING... HOW CAN IT BE BAD....
Kungfuking Removable Clamp Desktop Power Station 4-Outlet Power Strip, Office Desk Mountable Power Outlet with 2 USB Charging Ports and 3 RJ45 Ports, Desk Edge Clamp Plug Socket
https://www.amazon.com/gp/offer-listing/B07WQG46KX/
zeekh
Upstate NY
I'd buy it if the name was stamped on it somewhere. Just for a conversation piece at work
gamp945
Bosch 12V 3 tool two battery kit $119 on Woot
Not on this platform so not sure if it's a great deal.
https://tools.woot.com/offers/bosch...content=Subheader-B&ref_=pe_3185080_515129900
I think this is a pretty good buy. I'm on the Bosch 12V and 18V platforms.
The small reciprocating saw (PS60-102) sells as a kit for about $89 (with 2 batteries) on sale. The drill driver (PS31) sells for less than $50 as a bare tool (eBay kit part-outs). That's about $140 for the main tools if you get the lowest prices available. The flashlight and bags are basically "freebies" and sweeten the deal.
lelandr
Thanks Duker. Grabbed the Felo screwdriver. Been wanting to check out one of those.
Sent from my TA-1052 using Tapatalk
Mctiger1985
Louisiana
casmurbax
Wilton, NY
Disposable Face Masks (Pack of 25ct)
https://www.amazon.com/gp/offer-listing/B084HLV6N2/
These can be very handy... like when a certain someone plugs the compressor into the waste oil tank not realizing the valve is on.... as 3 quarts of oil drain onto the floor.... just saying....
Stardust Spill Products 2SDGPF Universal Mediumweight Fine Fiber Pad, 15x18, Pack of 200
https://www.amazon.com/gp/offer-listing/B00GTKFSRK/
Mirka 23-321-060 Bulldog Gold 5-Inch 5-hole Heavy-Duty PSA Vacuum Disc 60 Grit
https://www.amazon.com/gp/offer-listing/B004BGC22S/
Coilhose Pneumatics TYP2536 Typhoon High Volume Blow Gun, 1/4-Inch NPT with 36-Inch Extension and High Flow Tip
https://www.amazon.com/gp/offer-listing/B008PZAA98/
No bots were used.
Thank you for posting Duke.:):bowdown:
still want to know about the oil tank
D
Duker
Livingston, TX
cas
The early bird gets the worm, good job!
Duker,
Thanks for the posts.
Bruce
Thanks Bruce!
No bots were used.
Lol, John, the oil waste tank or probably better known as a drain oil dolly for a lift uses compressed air to push the oil back out of the tank to drain. In moving the dolly over to where I was going to drain the tank I must have hit the valve handle and it opened enough to when I plugged in the air coupling and I turned to grab my container it had already started flowing.... down the side of the dolly and onto the floor.... i have a stack of those pads and as I mentioned they come in handy! I now also have a container of oilsorb, but hopefully I learned that lesson!
