Amazon Warehouse Deals
D
Duker
Livingston, TX
Forney 72849 Wire Wheel Brush, Industrial Pro Stringer Bead Twist Knot with 5/8-Inch-11 Threaded Arbor, 5-Inch-by-.020-Inch​
D
Duker
Livingston, TX
D
Duker
Livingston, TX
Breeze - 9228H Liner Stainless Steel Hose Clamp, Worm-Drive, SAE Size 28, 1-5/16" to 2-1/4" Diameter Range, 1/2" Band Width (Pack of 10)​
That’s it for today! Have an excellent 4th of July!
jetrep
Thanks Duker!
hottytoddy
DFW
YIYITOOLS 74-piece 1/4" Drive Socket Set,1/4-Inch Drive Master Socket Set with Ratchets,Universal Joint, Extensions with 1/4’‘ Drive Bits Set, Inch/Metric, 6-Point, 5/32-Inch- 9/16-Inch, 4 mm-14 mm.
by Amazon.com
$30.28
I’m not sure about the quality but this is a very comprehensive set for the price. I figure I can replace the ratchet if it’s a turd with something better and how “bad” can the sockets be?
GeoBruin
Crabman
Alexandria, VA/Dameron, MD
Grace USA GRRS12 Professional Steel Roll Pin Punch Set with Vinyl Pouch, Gunsmith Tools & Accessories, 12 Piece, Black​
Regular $109.99, used very good $53.03
Ign
Butte Peak ND
Good morning Geo. Needed coffee.
Chicago Pneumatic CP9105Q-B Heavy Duty Die Grinder with Inbuilt Air Regulator, 28,000 RPM​
Regular $79.99, used good $38.67
Well shucks I didn't think "inbuilt" was really a word but Google says it is. So I learned my one thing for the day early, now I can turn off what little brain I have left for the rest of my Saturday - woohoo!
Crabman
Channellock 910 9" Cable/Wire Cutter with Compound Joint​
Regular $42.95, used very good $30.96
That's it for me today! My tomatoes are coming in, so distracted myself with a couple of big cookie sheets of bacon in the oven. Only set the smoke alarm off once. Have a great weekend!
Crabman
Stumbled into this looking for a portable a/c for one of my sheds that has funky windows.
Looks like a smoking deal, might be good for the people who want to get ready for the next heat wave. I bought one for a stash for when one of my units blows up.FrigAC.jpg
FRIGIDAIRE 5,000 BTU 115V Window-Mounted Mini-Compact Air Conditioner with Mechanical Controls, White​
Regular $209.99, on sale for $88.26, I bet it will not last long.
Edit to update link info, links not working, do a search for air conditioner, then hit used down on the left, you should see it, valid as of 3"19 eastern time
PlantItDeep
Precision Instruments 3/4" Split Beam Torque Wrench - $319.19 Used Very Good
Not for me as I need to be able to torque in both directions, but otherwise I would be on it
