Amazon Warehouse Deals
Sumboodie
AK
Happy weekend y'all! Hopefully you get some good deals throughout!
Duker- you had me severely questioning my need/want with that Williams 1" drive ratchet. Good thing I'm such a strong willed person and stuck to my instincts! (which means I definitely caved and ordered it..)
NBA Chicago Bulls Padded Swivel Bar Stool with Back
I know.. an odd addition, but would make a good garage stool, looks to be a sturdy build?
Used- $44
Std- $139
ATEQ VT30 Universal TPMS Activation and TPMS Reset Tool for Sensor Decoding and Domestic and European TPMS resets, manual and auto relearns
Used- $79
Std- $199
GEARWRENCH Pitman Arm Puller - 2289D
Used- $11
Std- $28
HyLoft Model 01012 Tire-Loft Multi Tire Storage System, 48-Inch wide by 36-Inch Deep,Red
Used- $65
Std- $137
DUNWELL Vertical360 LED Work Light – 5000 Lumens – Portable Work Light with All-Around Brightness – Collapsible, Standing LED Light Ideal for Garages, Shops, Attics & More, Green
Used- $60
Std- $186
Aain® AH48 Electric Garage Heater, 240 Volt Garage Space Heater, 4800 Watt,60Hz for Garage,Warehouse or Workshop
I've had one of these heaters as a supplemental for cold days for close to 20 years now and it's still alive and kicking. Different brand, but still...
Used- $53
Std- $119
Makita B-80014 50 Foot High Pressure Contractor Hose, Blue
Used- $42
Std-$ 146
I must be blind. That purple to me.
wantedabiggergarage
Member Emeritus
Independence, MO, USA.
I’d like that 48” pipe wrench but don’t know what I would use it for. Maybe hang it over the mantle instead of a gun.
Years ago, I almost bought a Ridgid one at a local estate/second hand store, for $20. It was in my hand when someone came in specifically looking for it for some farm property stuff.
Probably saved me from tripping over it and breaking my foot.
Nvrplzd
NCR
Sir, I believe you are just asking the wrong question from the get-go.
The real question should really be what could you NOT use it for? Walking stick? Check. New putter? Check. Garden hose to sprinkler attachment? Even better!
Nick Danger
Albuquerque
I got the Milton tire inflator. Thank you.
The used Milton tire inflator turned out to be junk. It has an internal leak. There are negative reviews from other people who had the same experience.
The previous owner of this one took it apart and re-sealed the threads with teflon tape. That didn't stop the leak. Amazon told me to send it back. If it turns up again as an AWD, don't you guys buy it.
vwpieces
Hills, PA
4 Pack 4FT Linkable LED Shop Light, Utility Shop Light Fixture, 4400lm, 42W [250W Equivalent], 5000K Daylight White Shop Lights for Garage,Hanging or Surface Mount, W/ Power Cord, ETL, Opens in a new tab
Nvrplzd
NCR
logixjock
Sturgeon, MO
Sir. I did not NEED this, nor do I appreciate this being posted while I may or may not be a weak man several drinks deep. However. What could happen, has happened and I will finally be able to remove this set from my “save for later” list.
Have a great weekend!
I appreciate you taking this temptation away from me.
vwpieces
Hills, PA
motorcycle79
wisconsin
Almost as bad as avocado green appliances. We actually threw out some of that stuff when we gut renovated our kitchen 5 years ago. Brought back memories, just not good ones haha!
Ha I would love a vintage refrigerator. One man’s trash is anothers treasure. For the garage anyway
superspec
WM louisiana
It took me a while off following this thread before I discovered where you guys were seeing these prices and then I later on figured out that there is probably only one at that price.
I try to keep up to date with this thread daily now instead of weekly
