Amazon Warehouse Deals
PlantItDeep
I've been watching for a good price on a Posi Lock 104 and would have bought one of the 102's if still available. Those used prices sure sell quickly.
Posi Lock makes great pullers
just be warned that 102 is really a tiny puller - I have 202 (2 arm version). Very specific use case
A 104 is a lot bigger (even if specs make them look similar)
PlantItDeep
smintman
PlantItDeep
Used like new $152
Should be made in Taiwan - someone else may be able to identify actual manufacturer?
Performance Tool M204 3/4-Inch Drive Torque Wrench with LH/RH Thread Torque Capabilities - 100 to 600 ft/lbs of torque​
PlantItDeep
Starting to see a few more ok deals show back up it seems
Mahle Elite Sportsman pistons BBC, $261
Awesome deal if you need them and they arrive in good shape
V8 super thin wrench set $20
Buyers Products P45AC6K 45 Ton Air Compensated Pintle Hook, 6-Hole Mount With Brake Chamber Bracket $93 (just the pintle is usually more)
OEMTOOLS 22992 5 Piece Spiral Type Extractor Set $21
Performance Tool W84004 Heavy Duty Hydraulic Valve Lifter Remover$17.9
Sunex 0586, 2 11/16 socket 1inch drive $26.5
Lisle 50600 Spring Brake Tool for GM, U.S. $18
Wall Control 30-P-3232B Black Metal Pegboard Pack - (2) 32" Tall x 16" Wide Black Pegboards $38
Performance Tool W5226 SEA/Metric Nut and Bolt Assortment with Case, 1,200 pieces $25
Probably missing some peices or cracked plastic
Lang Tools (3497 6-Piece Fixed Tip Combination Internal/External Snap Ring Pliers Set, Black, One Size $49
Lisle 60050 Heavy-Duty Yoke Puller $134
Wilde G254P $19.5
Should be made in USA :)
41 Inches Systems Pig Tail Step-in Fence Post,Stainless Steel for Fence - Pack of 30 White $86
This style is by far the most durable if you need temporary electric fence
Lisle 59600 Deutsch Terminal Tool $13.6
Tekton 37526, 16" slip joint pliers $22
Also made in USA :)
WildBill
PNW
Unfortunately there is a good chance you will only get one piston, that a steal for 8 though. Those are around $1k a set normally.
WildBill
PNW
"IF" you only get one you can always return it and get a full refund…….. That is the best thing about dealing with the "Big A"
BTW! Great deal on a set of 8! :thumbup:
Yeah, I buy 90% of my stuff from the warehouse, almost all the parts for my project vehicles. it's easy to return stuff and they usually just let me keep it and give me a refund. I have made custom Amazon shortcuts for each of my vehicles that search the warehouse by a defined percentage off. Just disappointing sometimes, I've grabbed 4-5 different piston "sets of 8" that turned out to be only one. I have never gotten 8 pistons from the warehouse.
MAYBEN
Sparta, NJ
Can you share more details how to set up the searches? Might be helpful for my two Pontiacs!
Thanks!
WildBill
PNW
Sumboodie
AK
fartymarty
Fort Worth
That good ol' ignoramus compressor.
It's like 2hp, it's tiny. Maybe 1500lbs.
Quoted weight includes operator/air supplier
3g0miaus-jpeg.2140207
