Amazon Warehouse Deals
capm
Ohio Andy
Columbus, Ohio
Opps sorry. Try starting in 2000 and go to 2016 or so I think it was flat high to high. I try to forget those years. All the gains came after 2009 or so. those years finally made up for the start of the millennium. At least I didn’t stay invested in the Nikkei since 1989.
All I know is that as a philatelist, and the way they package and sell stamps has made it very expensive to collect stamps.
vwpieces
Hills, PA
With a couple of exceptions, the three drawer and five drawer cabinets are all the same, with different labels. True of both Vevor and Huot. These are both the standard 3-drawer, 29 bin, layout.
I grabbed the Huot.
Yeah, I intended to change the label as I saw it had 29 slots. Prolly should have shopped around more. Vevor is a better price...
Cruzan80
Denver, CO
Not quite. The fractional one is 13 slots on top that you linked, and the tap version Duker linked is 12 slots. The second and third drawers both have 9 and 7 respectively. So Huot's tap one is only 12 (or has an unmarked 13th slot)...
Mostly posting so people that were in a rush didn't grab one thinking it was the other. Personally, I like (and have a couple) of the older Huot's with raised lettering on the drawers (makes it much harder to change labels...)
capm
The Huot has an unmarked 13th slot. Most of the three drawer Huots are identical except for the labels.
I think all of the three drawer Vevors are identical (they don't make some of the specials Huot does).
[Oops, I take that back. I have an old 27 bin Vevor with an 11 bin top drawer.]
The biggest difference between the Huot and the Vevor is that the dividers in the Huot are removable, and in the top drawer don't go all the way back leaving a wide storage space in the back. The Vevor dividers are welded and go all the way back.
Because of that I like the Huot better, even though the Vevor has slightly better drawer slides (bb vs one piece slide).
PugetDude
Superstition Mountains, AZ
demarpaint
Long Island
vwpieces
Hills, PA
Merry Christmas!
Griot's Garage B140F5 5.5" BOSS Finishing Foam Pads (Pack of 2)​
186 ratings
Size: 5.5 Inch Pads (Set of 2)
See all product options
New
$35.98$35.98
FREE delivery Saturday, December 28. Order within 10 hrs 27 mins
Add to Cart
See more
1 other option​
Used - Acceptable
$7.18$7.18
SUNEX TOOLS 445M 3/4" Drive Standard 6 Point Metric Impact Socket 45mm​
74 ratings
New
$27.61$27.61
FREE delivery Saturday, December 28. Order within 10 hrs 25 mins
Add to Cart
See more
15 other options​
sorted by price + delivery: low to high
Filter
Used - Very Good
$7.30$7.30
Karebac LR6C150 Premium Gold 6" PSA 150 C-Weight Aluminium Oxide Stearated 100 Sanding Discs/Linkroll Grit Sanding Discs, 150 Grit​
936 ratings
Style: 150 Grit
New
$18.12$18.12
$0.18 per Count($0.18$0.18 / Count)
FREE delivery Saturday, December 28. Order within 10 hrs 24 mins
Add to Cart
See more
1 other option​
Used - Very Good
$7.95$7.95
$0.08 per Count($0.08$0.08 / Count)
Weiler 59494 Wolverine Aluminum Oxide Resin Fiber Sanding & Grinding Disc, 4" Diameter, 60 Grit, 5/8" Arbor Hole (Pack of 25)​
75 ratings
Style: 5/8” Arbor , Size: 60 Grit
New
$19.20$19.20
$0.77 per Count($0.77$0.77 / Count)
FREE delivery Saturday, December 28. Order within 10 hrs 23 mins
Add to Cart
See more
3 other options​
Filter
Used - Like New
$8.08$8.08
$0.32 per Count($0.32$0.32 / Count)
Briggs and Stratton 7041939BZYP Blade, 21" Mulch​
79 ratings
New
$28.78 with 5 percent savings-5% $28.78
Typical price: $30.43Typical price: $30.43$30.43
FREE delivery Thursday, January 2. Details
Add to Cart
See more
8 other options​
Filter
Used - Very Good
$8.26$8.26
vwpieces
Hills, PA
Teng Tools 34MM 3/4 Inch Drive 6 Point Metric Deep Chrome Molybdenum Impact Socket | Mechanic Tool | Hand Tool - 940634-C​
56 ratings
New
$32.99$32.99
FREE delivery January 2 - 6. Details
Add to Cart
See more
1 other option​
Used - Like New
$8.90$8.90
Math says 50pk, but with 3M you just might get ONE. Still a deal at retail too.
3M Hookit Paper Disc 236U, P320 C-weight, 6 in x NH, Die 600Z​
2 ratings
New
$12.07$12.07
$0.24 per Count($0.24$0.24 / Count)
FREE delivery Sunday, December 29. Order within 10 hrs 19 mins
Add to Cart
See more
1 other option​
Used - Very Good
$8.93$8.93
BHA 6” Green Film PSA Self Adhesive Sanding Discs - 50 Pack - Wet/Dry, Sticky Back, Premium Aluminum Oxide for Long-Lasting, Low-Dust & Load Resistant Sanding and Surface Finishing - 2000 Grits​
4 ratings
Style: 2000 Grit
New
$25.04$25.04
FREE delivery Saturday, December 28. Order within 10 hrs 18 mins
Add to Cart
See more
1 other option​
Used - Like New
$9.20$9.20
Sunex 560D 1" Drive Deep 6 Point Impact Socket 1-7/8"​
23 ratings
New
$30.77$30.77
FREE delivery Saturday, December 28. Order within 10 hrs 17 mins
Add to Cart
See more
16 other options​
Filter
Used - Like New
$9.60$9.60
Briggs & Stratton 4133 4-Pack Of 270528S Air Filter Foam Element​
1 rating
New
$36.92$36.92
FREE delivery January 5 - 8 for Prime members
Add to Cart
See more
8 other options​
Filter
Used - Like New
$9.92$9.92
IVY Classic 48086 SDS Max 3 x 12-Inch Scaling Chisel, Chrome Molybdenum Steel, 1/Card​
10 ratings
New
$30.49$30.49
FREE delivery Sunday, December 29. Order within 10 hrs 16 mins
Add to Cart
See more
2 other options​
Filter
Used - Very Good
$10.15$10.15
Starrett Bi-Metal Deep Cut Hole Saw with Arbor and Abrasion Resistant HSS Teeth - Ideal for Cutting Metal, Steel, and Wood - 1-9/16" (40MM) Diameter, 2" Depth - ADCH0196​
1,331 ratings
New
$19.80$19.80
FREE delivery Monday, December 30. Order within 10 hrs 11 mins
Add to Cart
See more
3 other options​
Filter
Used - Like New
$10.78$10.78
Accusize Industrial Tools 3/4'' x 3/4'' x 5'' (Width x Height x Oal) H.S.S. Plus 5% Cobalt Lathe Tool Bit, 5095-0052​
241 ratings
Item Package Quantity: 1 , Size: 3/4" Dia 5" Length
New
$39.20$39.20
See more
2 other options​
Filter
Used - Like New
$12.02$12.02
vwpieces
Hills, PA
Trend Mini Flexible Curve Guide for Routing Accurate and Precise Curves with your Router, 19-1/2” long by 5/16" wide, CURV/8X500​
98 ratings
Size: 19 1/2 Inch Length
New
$27.95$27.95
FREE delivery Saturday, December 28. Order within 10 hrs 6 mins
Add to Cart
See more
1 other option​
Used - Like New
$13.09$13.09
YONICO Router Bits Lock Miter 45 Degree - Up to 3/4-Inch Stock 1/4-Inch Shank 15127q​
1,056 ratings
Style: 5/8" to 3/4" Stock - 1/4" Shank
New
$24.95$24.95
FREE delivery Saturday, December 28. Order within 10 hrs 5 mins
Add to Cart
See more
3 other options​
Filter
Used - Very Good
$13.43$13.43
Add to Cart
Condition
Looks and functions as if it were new. Item may not come in original packaging.
Ships from
Amazon.com
Sold by
Amazon Resale
Used - Like New
$13.85$13.85
Mercer Industries 225120 Mercer 9x11 Aluminum Oxide Cloth Sheets Grit 120X, 50 Pack,​
89 ratings
Size: Grit 120X , Style: Grit 120
New
$28.12 with 8 percent savings-8% $28.12
Typical price: $30.48Typical price: $30.48$30.48
FREE delivery Tuesday, December 31. Order within 10 hrs 5 mins
Add to Cart
See more
1 other option​
Used - Like New
$13.46$13.46
TEKTON 1-11/16 Inch Combination Wrench | WCB23043​
6,310 ratings
Style: Standard , Size: 1-11/16 in.
New
$60.00$60.00
FREE delivery Friday, January 3 for Prime members
Add to Cart
See more
9 other options​
Filter
Used - Like New
$14.02$14.02
PFERD Bench Grinding Wheel Universal Type | 7x1x1 inch, vitrified Bond, Regular Aluminum Oxide, grit Size 36 | 61754 - for Universal use in in The Workshop, Included bushings 3/4, 5/8, 1/2 inch​
2 ratings
New
$45.98$45.98
FREE delivery Monday, December 30. Order within 10 hrs 3 mins
Add to Cart
See more
5 other options​
Filter
Used - Acceptable
$14.47$14.47
Dico Products 7200075/4.5" Gray Nyalox Wheel Brush, 4.5", Gray​
10 ratings
New
$25.06$25.06
FREE delivery Saturday, December 28. Order within 10 hrs 2 mins
Add to Cart
See more
14 other options​
Filter
Used - Like New
$14.75$14.75
Yost Vises MA-360 Universal 6" Magnetic Aluminium Vise Jaw Caps Smooth Serrated Vise Jaw Cover Jaw Cover fits 6" Inch Vise Easily Attach with Magnet Strip - No Bolts Needed 1 Pair​
43 ratings
New
$42.99$42.99
FREE delivery January 2 - 7. Details
Add to Cart
See more
2 other options​
Filter
Used - Very Good
$15.24$15.24
vwpieces
Hills, PA
KNIPEX Tools - Circlip Pliers, External, 90 Degree Angled, Forged Tip, 3/4"-2 23/64" Shaft Dia. (4621A21), 6.75 , Black​
222 ratings
New
$26.67$26.67
FREE delivery Saturday, December 28. Order within 10 hrs 1 min
Add to Cart
See more
23 other options​
Filter
Used - Acceptable
$15.44$15.44
Mercer Industries 205100C - 9 x 11 Garnet Paper Sheets, Grit 100C (100 pack)​
284 ratings
Size: Grit 100C , Style: 100 pack
New
$43.04$43.04
FREE delivery Sunday, December 29. Order within 9 hrs 52 mins
Add to Cart
See more
1 other option​
Used - Like New
$18.85$18.85
Williams JHW472 Adjustable Hook Spanner Wrench with Span Diameter of 1-1/4 to 3-Inch, Ideal for Adjusting Collars, Lock Nut Rings, and Bearings​
415 ratings
Size: Span Diameter: 1 1/4 to 3 Inch , Style: Hook Spanner
New
$38.95$38.95
FREE delivery Saturday, December 28. Order within 9 hrs 52 mins
Add to Cart
See more
8 other options​
Filter
Used - Good
$18.86$18.86
Add to Cart
Condition
Minor cosmetic damage on top, front or side of the item. Item may not come in original packaging.
Ships from
Amazon.com
Sold by
Amazon Resale
Used - Very Good
$19.68$19.68
Ball Pein Hammer, Steel, Steel, 24 oz.​
1 rating
New
$29.21$29.21
FREE delivery Saturday, December 28. Order within 9 hrs 51 mins
Add to Cart
See more
11 other options​
Filter
Used - Acceptable
$20.37$20.37
vwpieces
Hills, PA
Weiler 08125 8" Standard Twist Knot Wire Wheel, .0118" Steel Fill, 5/8" Arbor Hole, Made in The USA (Pack of 2)​
84 ratings
Size: 0.0118" Wire Size , Style: Pack of 2
New
$58.00$58.00
$29.00 per Count($29.00$29.00 / Count)
FREE delivery Sunday, December 29. Order within 9 hrs 48 mins
Add to Cart
See more
4 other options​
Filter
Used - Very Good
$21.87$21.87
$10.94 per Count($10.94$10.94 / Count)
OTC Tools 552948 Replacement Sanding Pad, 10 Pack​
41 ratings
New
$50.65$50.65
$5.07 per Count($5.07$5.07 / Count)
FREE delivery Sunday, December 29. Order within 9 hrs 47 mins
Add to Cart
See more
10 other options​
Filter
Used - Acceptable
$23.37$23.37
$2.34 per Count($2.34$2.34 / Count)
Milton 1019-8 3/8" NPT Metal FRL Filter​
13 ratings
Size: 1019-8 3/8" NPT , Style: Milton Metal Micro Filter
New
$50.55$50.55
FREE delivery Saturday, December 28. Order within 9 hrs 47 mins
Add to Cart
See more
10 other options​
Filter
Used - Very Good
$24.23$24.23
Grey Pneumatic (1213) 3/8" Drive 12-Piece Standard Socket Set​
530 ratings
Style: 12 Piece Standard Set
New
$39.07$39.07
FREE delivery Saturday, December 28. Order within 9 hrs 46 mins
Add to Cart
See more
24 other options​
Filter
Used - Like New
$25.86$25.86
TooTaci Hydraulic Crimping Tool with 1Pair 1/8" Dies, Upgraded Custom Hydraulic Hand Crimper Tool for 1/8" Stainless Steel Cable Railing Fittings, Hardware Wire Rope Swaging Dies​
New
$39.99$39.99
Up to 5% off if you qualify Shop items
Add to Cart
See more
1 other option​
Used - Like New
$26.13$26.13
Amana Tool - 47129 Carbide Tipped Dynabit Laminate Flush Trim 1/2 Dia x 2" x 1/2 Shank​
25 ratings
Size: 1/2 Dia x 2" x 1/2 Shank
New
$57.15$57.15
FREE delivery Monday, December 30. Order within 9 hrs 45 mins
Add to Cart
See more
2 other options​
Filter
Used - Like New
$26.64$26.64
KNIPEX - 38 15 200 Tools - Long Nose Pliers Without Cutter, Multi-Component (3815200)​
42 ratings
New
$43.08$43.08
FREE delivery Saturday, December 28. Order within 9 hrs 45 mins
Add to Cart
See more
15 other options​
Filter
Used - Like New
$26.72$26.72
vwpieces
Hills, PA
3M Stikit Gold Disc Roll 236U, 01443, 6 in, P80 Grade, 125 Discs Per Roll, Automoitve Abrasives​
17 ratings
Size: ERROR:#REF! , Style: Grit: P80A
New
$79.25 with 30 percent savings-30% $79.25
List Price: $112.77List Price: $112.77$112.77
FREE delivery Saturday, December 28. Order within 9 hrs 44 mins
Add to Cart
See more
22 other options​
Filter
Used - Very Good
$29.15$29.15
LENOX Tools Tubing Cutters Set for Tight Spaces, 3-Piece (14833TSK)​
1,407 ratings
New
$50.95$50.95
Add to Cart
See more
10 other options​
Filter
Used - Acceptable
$29.19$29.19
KNIPEX Dismantling Knife-1000V Insulated​
839 ratings
Style: Dismantling Knife
New
$54.69$54.69
FREE delivery Saturday, December 28. Order within 9 hrs 43 mins
Add to Cart
See more
7 other options​
Filter
Used - Good
$30.22$30.22
When my dad worked in industrial electrical maintenance, he had a pail of wire pulling lube. At home we used it as hand cleaner. Stuff was the same as the cream hand cleaner... even smelled the same.
But I can't say this is the same SHtuff.... If so, 5 gal for $30 is a deal.
Gardner Bender 79-203 Poly-Gel, Cable Pulling Lubricant, 28° - 200°F, Dries Clear, Conduit & Fiber-Optic Cable Insulation, 5 Gal. Bucket, Blue​
93 ratings
Style: 5 Gal. Pail
New
$90.24$90.24
FREE delivery Sunday, December 29. Order within 9 hrs 42 mins
Add to Cart
See more
1 other option​
Used - Like New
$32.07$32.07
KNIPEX External 90 Angled Precision Snap Ring Pliers​
6 ratings
New
$65.62$65.62
FREE delivery Tuesday, December 31. Order within 9 hrs 39 mins
Add to Cart
See more
12 other options​
Filter
Used - Like New
$32.40$32.40
Titan 17289 7-Piece 12-Point Metric Jumbo Combination Wrench Set​
New
$110.82$110.82
FREE delivery Saturday, December 28. Order within 9 hrs 39 mins
Add to Cart
See more
2 other options​
Filter
Used - Like New
$32.99$32.99
Yost Vises 3D 3.5 Inch General-Purpose Drill Press Vise with Stationary Base 3.5 Inch Jaw Width Heavy-Duty Utility Bench Vise Made of Structural Cast Steel Made in Taiwan​
15 ratings
New
$69.99 with 63 percent savings-63% $69.99
List Price: $188.16List Price: $188.16$188.16
Add to Cart
See more
1 other option​
Used - Like New
$36.71$36.71
Milton 1035 1/4" NPT Metal FRL Coalescing Filter​
1 rating
New
$98.43$98.43
FREE delivery for Prime members
Add to Cart
See more
5 other options​
Filter
Used - Like New
$39.42$39.42
BESSEY CDF412 12 In. x 5-3/4 In. Black Oxide Spindle Drop Forged C Clamp​
20 ratings
Size: 12 in. , Style: 9,300 lb Force
New
$107.99 with 15 percent savings-15% $107.99
List Price: $127.45List Price: $127.45$127.45
FREE delivery Saturday, December 28. Order within 9 hrs 36 mins
Add to Cart
See more
14 other options​
Filter
Used - Good
$39.72$39.72
SK Tools USA 6 Piece, CushionGrip Automotive Combination Screwdriver Set | 86336​
34 ratings
New
$65.49$65.49
Add to Cart
See more
5 other options​
Filter
Used - Acceptable
$43.59$43.59
Wilton C-Clamp, 8-1/4" Opening, 4-15/16" Throat, 6900 Lbs. Clamping Force (Model 408)​
48 ratings
New
$74.31$74.31
FREE delivery Saturday, December 28. Order within 9 hrs 35 mins
Add to Cart
See more
25 other options​
Filter
Used - Very Good
$44.04$44.04
KNIPEX CoBolt High Leverage 20 Angle Compact Bolt Cut Notched Blade​
56 ratings
New
$65.99$65.99
FREE delivery Saturday, December 28. Order within 9 hrs 34 mins
Add to Cart
See more
18 other options​
Filter
Used - Like New
$45.63$45.63
Astro Pneumatic Tool 7306 Adjustable 7 Foot Paint Hanger , Blue, 1 Count (Pack of 1)​
258 ratings
New
$106.99$106.99
FREE delivery Monday, December 30. Order within 9 hrs 33 mins
Add to Cart
See more
20 other options​
Filter
Used - Very Good
$49.19$49.19
Akro-Mils 33224 Akro-Grid Plastic Slotted Dividable Modu Box Stackable Grid Storage Tote Container, (22-3/8-Inch L x 17-3/8-Inch W x 4-Inch H), (6 Pack), Blue​
6 ratings
Color: Blue
New
$186.76$186.76
$31.13 per Count($31.13$31.13 / Count)
FREE delivery Friday, December 27. Order within 9 hrs 33 mins
Add to Cart
See more
7 other options​
Filter
Used - Like New
$49.95$49.95
$8.33 per Count($8.33$8.33 / Count)
Jitterbug Air Pneumatic Automatic Palm Hammer Handheld Pneumatic Hammer Auto Body 1000 Stroke bpm with Ultra Soft Plastic Hammer Tip for Tire Repair Vehicle Maintenance​
3 ratings
New
$112.00$112.00
Save 10% on 2 select item(s) Shop items
FREE delivery January 7 - 17. Details
Add to Cart
See more
2 other options​
Filter
Used - Acceptable
$54.85$54.85
Mayhew Tools 61397 Knurled Brass Punch and Scraper Set, Metric, 12-Piece​
2 ratings
Size: 12 Piece , Style: Metric
New
$93.07$93.07
FREE delivery Sunday, December 29. Order within 9 hrs 30 mins
Add to Cart
See more
18 other options​
Filter
Used - Like New
$61.80$61.80
vwpieces
Hills, PA
Wilton B.A.S.H 30" Sledge Hammer, 8 Lb Head (20830)​
39 ratings
New
$115.99$115.99
FREE delivery Saturday, December 28. Order within 9 hrs 25 mins
Add to Cart
See more
25 other options​
Filter
Used - Like New
$64.01$64.01
Chicago Pneumatic CP7215 - Air Random Orbital Sander Tool, Home Improvement, Woodworking Tools, Polisher, Rust Removal, Sanding Tool, Non-Vacuum, PSA, 6 Inch (150 mm), 0.28 HP / 210 W - 12000 RPM, One Size, Factory​
25 ratings
Style: Non-Vacuum, PSA Pad , Size: One Size
New
$206.91$206.91
FREE delivery Tuesday, December 31. Order within 9 hrs 24 mins
Add to Cart
See more
9 other options​
Filter
Used - Like New
$70.08$70.08
Wilton Spark-Duty Heavy F-Clamp, 36" Opening, 7" Throat, 4880 Lbs. Clamping Force (Model 4800S-36C)​
1 rating
New
$286.71$286.71
Add to Cart
See more
8 other options​
Filter
Used - Like New
$93.69$93.69
OIL SHIELD OSRHD3850 18 ga. Retractable Hose Reel with 3/8" x 50' Air Hose, 3' Lead-in Hose, Next-Gen Ultra-Light and Super Strong Rubber, 12 Point Ratchet System​
7 ratings
Size: 3/8" x 50' HD Reel
New
$197.49 with 21 percent savings-21% $197.49
List Price: $249.00List Price: $249.00$249.00
FREE delivery Sunday, December 29. Order within 9 hrs 21 mins
Add to Cart
See more
11 other options​
Filter
Used - Like New
$94.23$94.23
Milton 1632-200 200 Foot 3/8" ID EPDM Rubber Air Hose​
50 ratings
Style: 3/8" ID EPDM , Size: 200 FT
New
$234.56$234.56
FREE delivery Saturday, December 28. Order within 9 hrs 20 mins
Add to Cart
See more
6 other options​
Filter
Used - Very Good
$116.01$116.01
Triton TWSS10 Slow Speed Wetstone Sharpener with a High Grade Grindstone​
19 ratings
Used - Good
$155.41$155.41
FREE delivery Monday, December 30. Order within 9 hrs 19 mins
Add to Cart
See more
2 other options​
Filter
Used - Like New
$167.23$167.23
FREE delivery Tuesday, December 31. Order within 9 hrs 19 mins
Add to Cart
Condition
Looks and functions as if it were new. Item will come in original packaging.
Ships from
Amazon.com
Sold by
Amazon Resale
New
$395.09$395.09
finn
The UP, God's country
Got the like new used 1/8" wire crimper. Going to come in handing for new deck railing.
I bought one of them last year. The same tool is sold under multiple brands in different colors.
It made it through my railing project, but it always raises eyebrows when the manufacturer includes spare parts (o rings) to repair it when, not if, it breaks.
