Amazon Warehouse Deals
D
Duker
Livingston, TX
Nvrplzd
NCR
KING PSH1215T Yellow Jacket Portable Shop Heater w/Thermostat, 1500W / 120V
Used price: $43
Std price: $128
3M applicator gun
Used price: $38
Std price: $128
MIG torch stinger
Used price: $27
Std price: $95
Portable LED light and battery pack
Used price: $33
Std price: $ 117
Triplett Magnetic Field meter
Used price: $26
Std price: $109
Lufkin 100’ tape
Used price: $79
Std price: $20
Nvrplzd
NCR
Impact 7504 Foam Gun, 96 oz Capacity, 10" Length x 9-1/2" Width x 9-1/2" Height, Black/Translucent
Used price: $21
Std price: $78
Powerbuilt 641434 3/4" Drive Reversible Ratcheting Micrometer Torque Wrench
Used price: $116
Std price: $283
3M™ 101+ Masking Tape, 5.1 Mil, 2" x 60 yds, Tan, 24/Case, 3M Stock# 7000147264
Used price: $43
Std price: $127
Miller by Honeywell Twin Turbo G2 Connector Kit
Used price: $16
Std price: $64
Ingersoll Rand 7803RA 1/2” Reversible Pneumatic Air Drill, Heavy Duty, 400 RPM, Variable Speed Throttle, 5HP Motor, Quick Reverse Lever
Used price: $79
Std price: $220
General Tools CGD900 Intrinsically Safe MSHA Approved Combustible Gas Leak Detector
Used price: $78
Std price: $199
HexArmor VS350 Clear Anti Fog Safety Goggles 5 pack
Used price: $44
Std price: $122
Yost Vises 908-AS 8" Heavy Duty Steel Bench Vise
Used price: $148
Std price: $325
Nvrplzd
NCR
My apologies if the format was off, just trying to pay it forward a bit for all of the deals I’ve scored from this thread. (That and it’s good justification to the boss at home that I can find deals and NOT have to buy them all.
Nvrplzd
NCR
Sunex Engine Transverse Bar-
Used- $63
Std- $148
Williams Ratcheting Flare Nut Wrench 3/4"
Used- $13
Std- $ 38
Tekton 12" bar clamp
Used- $7
Std- 17
Ingersoll Rand 1/2" Pneumatic Drill Keyless Chuck
Used- $93
Std- $298
Ingersoll Rand 1/4" Regulator/Lubricator unit
Used- $68
Std- $166
Drill America 33 Piece 135 degree Reduced Shank Cobalt drill bit set (showing lowest price since 2018)
Used- $474
Std- $1,262
Campbell Hausfeld 3/8" pneumatic drill
Used- $28
Std- $56
COXREELS P-LP-325-HV Retractable Hose reel 3/8"x25'
Used- $110
Std- $357
PneumaticPlus PPF3-N03B Compressed Air Particulate Filter 3/8" NPT, 5 Micron, Poly Bowl, Manual Drain, Bracket
Used- $11 & $12 (2 available)
Std- $27
SNS AR3000-N03 Female Thread 3/8 NPT Air Pressure Regulator 0-150 PSI Adjustable,Bracket,Gauge
Used- $15
Std- $30
HEAVY DUTY IN-LINE COMPRESSED AIR PRESSURE REGULATOR FOR AIR COMPRESSOR, 7 TO 215 PSI ADJUSTABLE, HIGH FLOW RATE, WALL BRACKET AND GAUGE INCLUDED (1" NPT, 180 CFM)
Used- $22
Std- $59
Tire Pressure Gauge - XL Pro Edition By Federico's Car Care - 0 to 60 PSI
Used- $8
Std- $23
Longacre® 52-53000 Pro Digital Tire Pressure Gauge 0-60 psi
Used- $58
Std- $150
Milton Precision Digital Tire Pressure Gauge S-586e, Dual Head Air Chuck, Made In USA Most Accurate Inflator Gauge Available, Easy to Read Display, 0-160 PSI Pressure Range , Red
Used- $117
Std- $254
Nvrplzd
NCR
Mercer Industries 193030B Crimped Cup Brushes, 3" x 1/4" Hex Shank .014 Carbon Steel Wire, 20 Pack
Used- $21
Std- $57
Astro Pneumatic Tool PRN516 ONYX Pneumatic Rivet Nut Setting Gun W/Quick-Change 1/4" & 5/16" Mandrels
Used- $86
Std- $240
HARRIS 05356F6 5356 Aluminum MIG Welding Wire, 0.035" x 16 lb. Spool
Used- $65
Std- $141
Hubbell Workplace Solutions GR62410003 BD-03 Tool Balancer, Molded ABS Housing, 6' Long Galvanized Steel Aircraft Cable, Min/Max Capacity 1.5-3.0 lb.
Used- $21
Std- $67
QPKING Vehicle Panel Spot Puller Dent Spotter 3500A Spot Dent Puller, 7 Modes 3KW Spot Welding Machine, Car Body Stud Welder Dent Repair Kit, Multi-spot Bonnet Door Repair Tool 110V
Used- $168
Std- $359
AmazonCommercial Heavy Duty Double Diaphragm Transfer Pump 1/2" Nitrile / NBR / Buna-N - 13GPM / 50LPM Aluminum Air Operated Pneumatic for Diesel, Grease, Kerosene & Oil
Used- $70
Std- $338
Linemaster 597-EX Explosion Proof Foot Switch, Electrical, 2-Pedal, Momentary, Full Aluminum Guard, Orange
Used- $90
Std- $439
Tapha Tools Digital Torque Screwdriver 0.88 - 17.7 in-lbs (10 - 200 cN-m / 1.02 - 20.41 kg-cm) Torque Range, Accurate to ±2% Dual Direction, LED and Buzzer Notification, Preset Memory (SPN-T2BN)
Used- $115
Std- $245
Hornady Steel Dial Caliper
Used- $18
Std- $51
