QwikKotaTx
I had enough of the clutter down the middle and left of my garage, this weekend I built a 3 shelf setup out of 2x4's and 5/8" ply. It's not as stable laterally as I would have liked but for weight handling in compression it seems pretty stout. The shelf frames have 5 cross members including the ends and the vertical supports have 2 continuous 2x4's at the bottom and 2x4 blocks below the upper two shelves all held in with 2 long screws. Thank god for square drives. I pre-drilled the vertical pieces to avoid splitting as encountered on the shelf frames. I mainly store things in 18 gallon totes but also have misc boxes and lawn equipment on or under it. Bottom shelf sits at 24" for clearance for my pressure washer. I got lucky somehow in that I made the verticals 6' high and the drop worked for the bottom shelf support/legs. I may need to add some angle braces to increase lateral rigidity.
